This benchmark is based on the SAFENET task of the DECOVALEX 2027 project, which aims to better understand fracture nucleation and evolution processes in crystalline rocks with applications in nuclear waste management and geothermal reservoir engineering, and it simulates a 2D ideal model of the GREAT Cell experiment [1][2].
More details regarding boundary condition and order of PEEs can be found in the GREAT Cell experiment description.
The load conditions or the pressure applied on the segment PEEs are given in the table below:
| Marker | PEE1 Angle to $\sigma_2$ | PEE1 & 1a | PEE2 & 2a | PEE3 & 3a | PEE4 & 4a | PEE5 & 5a | PEE6 & 6a | PEE7 & 7a | PEE8 & 8a |
| F | 67.5° | 3.82 | 7.80 | 9.95 | 10.0 | 6.64 | 4.46 | 1.17 | 1.0 |
The load condition of each DSS is the average of the values of its two PEE neighbours. Rigid movement is avoided by fixing the displacement at the bottom point.
An existing fracture is assumed along the $x$ axis.
The material properties of the sample are given in the following table:
| Parameter | Value | Unit |
| Young’s modulus | 26.87e9 | Pa |
| Poisson’s ratio | 0.27 | – |
| Biot coefficient | 0.8 | – |
| Porosity | 0.005 | – |
| Permeability | 2.58e-19 | m² |
| Solid density | 2650 | kg/m³ |
| Normal stiffness | 100e9 | Pa/m |
| Tangential stiffness | 50e9 | Pa/m |
| Fluid compressibility (c_f) | 4.4e-10 | Pa⁻¹ |
| Solid bulk modulus (k_s) | 1.95e10 | Pa |
| Initial fracture width (w_init) | 1e-6 | m |
| Density | 1000.0 | kg/m³ |
| Viscosity | 1e-3 | Pa·s |
| Injection flow rate | 4.167e-7 | m³/s |
| Outlet pressure | 3.45e6 | Pa |
| Young’s modulus | 0.1e9 | Pa |
| Poisson’s ratio | 0.4 | – |
| Porosity | 0.001 | – |
| Permeability | 1e-17 | m² |
| Density | 1500 | kg/m³ |
| Biot coefficient | 0.0 | – |
The initial stresses in in the fracture are $\sigma_{nn}=0$ MPa and $\sigma_{tt}=-2$ MPa.
This benchmark uses the LIE and the B-bar methods.
McDermott, C.I., Fraser-Harris, A., Sauter, M., Couples, G.D., Edlmann, K., Kolditz, O., Lightbody, A., Somerville, J. and Wang, W., 2018. New experimental equipment recreating geo-reservoir conditions in large, fractured, porous samples to investigate coupled thermal, hydraulic and polyaxial stress processes. Scientific reports, 8(1), p.14549.
Mollaali, M., Kolditz, O., Hu, M., Park, C.H., Park, J.W., McDermott, C.I., Chittenden, N., Bond, A., Yoon, J.S., Zhou, J. and Pan, P.Z., Liu H., Hou W., Lei H., Zhang L., Nagel T., Barsch M., Wang W., Nguyen S., Kwon S. and Yoshioka K., 2023. Comparative verification of hydro-mechanical fracture behavior: Task G of international research project DECOVALEX–2023. International Journal of Rock Mechanics and Mining Sciences, 170, p.105530.
import os…
(click to toggle)
out_dir.mkdir(parents=True, exist_ok=True)project_file = Path("HM2b_LIE_F.prj")…
(click to toggle)
mesh_path = Path("mesh_GreatCell_embeddedFracture").resolve()
for b_bar in ["false", "true"]:
prj = ot.Project(
input_file=project_file, output_file=Path(out_dir, f"b-bar_{b_bar}.prj")
prj.replace_text("hm_lie_bbar_" + b_bar, xpath="./time_loop/output/prefix")
prj.replace_text(b_bar, xpath="./processes/process/use_b_bar")
prj.write_input()
prj.run_model(logfile=Path(out_dir, "out.txt"), args=f"-o {out_dir} -m {mesh_path}") ogs -o /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-all/Tests/Data/LIE/HydroMechanics/GreatCellWithBBar/great_cell_LIE -m /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/ogs/Tests/Data/LIE/HydroMechanics/GreatCellWithBBar/mesh_GreatCell_embeddedFracture /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-all/Tests/Data/LIE/HydroMechanics/GreatCellWithBBar/great_cell_LIE/b-bar_false.prj
['ogs', '-o', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-all/Tests/Data/LIE/HydroMechanics/GreatCellWithBBar/great_cell_LIE', '-m', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/ogs/Tests/Data/LIE/HydroMechanics/GreatCellWithBBar/mesh_GreatCell_embeddedFracture', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-all/Tests/Data/LIE/HydroMechanics/GreatCellWithBBar/great_cell_LIE/b-bar_false.prj']
ogs -o /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-all/Tests/Data/LIE/HydroMechanics/GreatCellWithBBar/great_cell_LIE -m /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/ogs/Tests/Data/LIE/HydroMechanics/GreatCellWithBBar/mesh_GreatCell_embeddedFracture /var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-all/Tests/Data/LIE/HydroMechanics/GreatCellWithBBar/great_cell_LIE/b-bar_true.prj
['ogs', '-o', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-all/Tests/Data/LIE/HydroMechanics/GreatCellWithBBar/great_cell_LIE', '-m', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/ogs/Tests/Data/LIE/HydroMechanics/GreatCellWithBBar/mesh_GreatCell_embeddedFracture', '/var/lib/gitlab-runner/builds/t1_R7hwLX/1/ogs/build/release-all/Tests/Data/LIE/HydroMechanics/GreatCellWithBBar/great_cell_LIE/b-bar_true.prj']
The figure below shows that the B-bar method improves the strain result significantly.
def inner_mesh(filename: str) -> pv.UnstructuredGrid:…
(click to toggle)
"Return submesh inside a radius of 0.065."
mesh = ot.MeshSeries(Path(out_dir, filename))[-1]
radii = np.asarray([np.linalg.norm(cell.center) for cell in mesh.cell])
return mesh.extract_cells(radii < 0.065)
plt.rcParams.update(
"font.family": "serif",
"font.size": 12,
"axes.labelsize": 12,
"axes.titlesize": 14,
"legend.fontsize": 8,
"xtick.labelsize": 10,
"ytick.labelsize": 10,
"lines.linewidth": 1.5,
"axes.linewidth": 0.8,
"grid.linewidth": 0.4,
"savefig.dpi": 600,
"mathtext.fontset": "stix",
def sorted_angles_eps_trace(filename: str) -> tuple[np.ndarray, np.ndarray]:
edge = inner_mesh(filename).extract_feature_edges()
eps_trace = ot.variables.strain.trace.transform(edge)
phi = np.arctan2(edge.points[:, 1], edge.points[:, 0]) * 180 / np.pi
phi[phi < 0] += 360
sort_idx = np.argsort(phi)
return (phi[sort_idx], eps_trace[sort_idx])
fig, (ax, ax_err) = plt.subplots(
2, 1, figsize=(7.0, 4.0), sharex=True, gridspec_kw={"height_ratios": [2, 1]}
series = {}
colors = {"true": "#c0392b", "false": "#e74c3c"}
for b_bar in ["true", "false"]:
angles, eps_v = sorted_angles_eps_trace(f"hm_lie_bbar_{b_bar}.pvd")
linestyle = {"false": "dotted", "true": "solid"}[b_bar]
ax.plot(
angles,
np.array(eps_v) * 100,
linestyle=linestyle,
label=rf"$B_{{\mathrm{{bar}}}} = {b_bar}$",
marker="o" if b_bar == "true" else "s",
markersize=4,
markerfacecolor="none",
markeredgewidth=1.0,
color=colors[b_bar],
series[b_bar] = (angles, eps_v)
ax.set_ylabel(r"Volumetric strain $\varepsilon_{\mathrm{vol}}$ / %", labelpad=5)
ax.set_xlim(0, 360)
ax.set_ylim(-4, 0)
ax.set_xticks(np.arange(0, 361, 45))
ax.grid(True, which="major", linestyle=":", linewidth=0.4, alpha=0.7)
ax.legend(
loc="lower right",
bbox_to_anchor=(0.98, 0.2),
frameon=True,
framealpha=0.95,
edgecolor="0.3",
borderpad=0.6,
phi_t, y_t = series["true"]
phi_f, y_f = series["false"]
if not np.array_equal(phi_t, phi_f):
y_f = np.interp(phi_t, phi_f, y_f)
err = y_t - y_f
ax_err.plot(phi_t, err, color="k")
ax_err.axhline(0, linestyle="--", linewidth=0.8, color="gray")
ax_err.set_xlabel(r"Angle $\theta$ / $^\circ$", labelpad=5)
ax_err.set_ylabel(r"$\Delta$ / %", labelpad=5)
ax_err.grid(True, which="major", linestyle=":", linewidth=0.4, alpha=0.7)
ax.minorticks_on()
ax.tick_params(which="minor", length=3, width=0.6)
ax.tick_params(which="major", length=5, width=0.8)
ax.tick_params(axis="both", which="both", direction="in", top=True, right=True)
ax_err.minorticks_on()
ax_err.tick_params(which="minor", length=3, width=0.6)
ax_err.tick_params(which="major", length=5, width=0.8)
ax_err.tick_params(axis="both", which="both", direction="in", top=True, right=True)
plt.tight_layout()
plt.savefig(
out_dir / "hm_lie_bbar_comparison.pdf",
dpi=600,
bbox_inches="tight",
pad_inches=0.05,
plt.close()
def plot_mesh_compare(…
(click to toggle)
file_true: Path,
file_false: Path,
colorbar_opts: dict,
save_file: Path | None = None,
domain_limit: float = 0.098,
mesh_true = ot.MeshSeries(file_true)[-1]
mesh_false = ot.MeshSeries(file_false)[-1]
has_p_true = "pressure" in mesh_true.point_data
has_p_false = "pressure" in mesh_false.point_data
include_pressure = has_p_true and has_p_false
rows = [
"$\\mathbf{u}$",
ot.variables.displacement.replace(output_unit="mm"),
"u",
("$\\mathrm{tr}(\\sigma)$", ot.variables.stress.trace, "stress"),
("$\\mathrm{tr}(\\varepsilon)$", ot.variables.strain.trace, "strain"),
if include_pressure:
rows.append(("$p$", ot.variables.pressure, "pressure"))
nrows = len(rows)
ncols = 2
figsize = (10 * ncols, 6 * nrows)
fig, axs = plt.subplots(
nrows=nrows, ncols=ncols, figsize=figsize, sharex=True, sharey=True
if nrows == 1:
axs = np.array([axs])
for i, (title, var, key) in enumerate(rows):
ot.plot.contourf(mesh_true, var, fig, axs[i, 0], **colorbar_opts[key])
axs[i, 0].set_title(f"{title} (bbar_true)", fontsize=22)
ot.plot.contourf(mesh_false, var, fig, axs[i, 1], **colorbar_opts[key])
axs[i, 1].set_title(f"{title} (bbar_false)", fontsize=22)
for ax in axs.ravel():
ax.set_aspect("equal")
ax.tick_params(labelsize=14)
ax.set_xlim(-domain_limit, domain_limit)
ax.set_ylim(-domain_limit, domain_limit)
if save_file:
Path(save_file).parent.mkdir(parents=True, exist_ok=True)
fig.savefig(save_file, dpi=300, bbox_inches="tight")
plt.close(fig)
colorbar_opts = {
"u": {"vmin": 0, "vmax": 0.25},
"stress": {"vmin": -15, "vmax": 5},
"strain": {"vmin": -0.05, "vmax": 0.005},
"pressure": {"vmin": 0.1, "vmax": 10},
plot_mesh_compare(
file_true=Path(out_dir, "hm_lie_bbar_true.pvd"),
file_false=Path(out_dir, "hm_lie_bbar_false.pvd"),
colorbar_opts=colorbar_opts,
save_file=Path(out_dir, "compare_bbar.png"),
Check the the volumetric strain at the specified circle against reference results.
expected_eps_v_bbar_true = np.array([-0.01490984255021392 , -0.013987665076443945, -0.013291145162162097, -0.012657186344186994,…
(click to toggle)
-0.012077562490951627, -0.011593306527156625, -0.011176316797253946, -0.01092569848731069 ,
-0.01091895899307576 , -0.010714526271895689, -0.01114387725791524 , -0.011504380671698598,
-0.012092934118127245, -0.012863844099957972, -0.013891307884180757, -0.014824422439206673,
-0.015842888407653168, -0.01698930615310603 , -0.01820004415291281 , -0.019311361785447873,
-0.02037186498737685 , -0.021381900264295425, -0.02267022167453655 , -0.023700791466756962,
-0.024651973931523918, -0.025834316049296095, -0.02665397856513444 , -0.02733189018996455 ,
-0.02770781423765582 , -0.028345819993573197, -0.028607888986588764, -0.028921395881402683,
-0.028527748160527878, -0.028321403010593223, -0.02785847219788058 , -0.02744136638137052 ,
-0.026451557317533896, -0.025586383474529427, -0.024539938245160493, -0.023466049965989697,
-0.022417380454526133, -0.02129466806681034 , -0.020118766322555316, -0.018890229381819928,
-0.017632516373885486, -0.01646493848269331 , -0.015464670523898097, -0.014562092590426413,
-0.013752144407338369, -0.013096148271584786, -0.012564590391080288, -0.012185082706746724,
-0.01199447428001041 , -0.011893699392594523, -0.012263204688720017, -0.01261592084988576 ,
-0.013186641784431212, -0.013856951863050332, -0.014948316001225192, -0.01588134762422188 ,
-0.0168738751033352 , -0.017887279415493056, -0.01882953072448892 , -0.0197989418783354 ,
-0.020800230539342886, -0.021787442243462178, -0.022928602250839102, -0.02382648570600328 ,
-0.02473887039251807 , -0.02554854198958239 , -0.026241011041587634, -0.026767411360017812,
-0.027160336582612497, -0.02742609130243981 , -0.027461460888973104, -0.027588143281204316,
-0.02706688976921454 , -0.026720468413761987, -0.02598620743929075 , -0.02534338104812332 ,
-0.023780857548122827, -0.022808214680706176, -0.021565074282019227, -0.02028192599371304 ,
-0.019043182295690863, -0.017844613487726778, -0.01677439282883159 , -0.01579129577134375 ]) # fmt: skip
eps_v_bbar = sorted_angles_eps_trace("hm_lie_bbar_true.pvd")[1]
np.testing.assert_allclose(
actual=eps_v_bbar, desired=expected_eps_v_bbar_true, atol=1e-10
)This article was written by Wenqing Wang, Florian Zill, and Mostafa Mollaali. If you are missing something or you find an error please let us know.
Generated with Hugo 0.150.1
in CI job 743172
Last revision: December 13, 2024
