Ground equilibrium
Test cases
Four versions of the test are presented:
We assume a two-dimensional piece of ground (linear elastic soil saturated with water) and consider two cases: The static equilibrium state under gravity load, and the temporal evolution under some additional indentation from the top. The corresponding boundary conditions are either coded directly in the prj-file or provided by pythonBCsOGS.py using the Python interface. See this PDF for the detailed description.
This article was written by Christian Silbermann, Thomas Nagel. If you are missing something or you find an error please let us know.
