Linear, single fracture
Equations
We solve a hydromechanics problem (small deformation, linear elastic, Darcy flow) with a pre-existing fracture using the lower-dimensional interface element (LIE) approach.
Result showing pore pressure increase due to the injection and subsequent fracture aperture increases at t=500s. A small discrepancy of the aperture near the injection is due to the interpolation method for converting cell data to point data in ParaView.
3D setup
Same setup as for the given 2D case above with additional plane strain conditions in the front and back x-y planes. Warp of the 1000-times oversized displacement and the fracture’s aperture are shown in the following figure.
Comparison with 2D setup yields identical results (up to numerical differences in order of 1e-15): TODO: Image missing!
This article was written by Norihiro Watanabe. If you are missing something or you find an error please let us know.
Generated with Hugo 0.147.9 in CI job 610044 | Last revision: August 7, 2025
Commit: [cmake,T] Fix testrunner in wheel config. 9e69f722  | Edit this page on
