LargeDeformations: Torsion of a hyperelastic bar
Convergence under large deformations (preliminary)
In this benchmark we impose large tensile and torsional deformations on a hyperelastic prismatic bar. The material model is a Saint-Venant-Kirchhoff material law for initial testing.
from ogstools import logparser
pv.set_jupyter_backend("static" if "CI" in os.environ else "client")(click to toggle)
model = ot.Project(input_file="bar1to6_torsion.prj", output_file="bar1to6_torsion.prj")(click to toggle)
model.run_model(logfile=out_dir / "out.txt", args=f"-o {out_dir}")
mesh = ot.MeshSeries(out_dir / "bar1to6_torsion.pvd")[-1]
Simulation: bar1to6_torsion.prj
Execution took 3.6328468322753906 s
Boundary conditions
The bar of dimensions $1 \times 1 \times 6$ m³ is stretched by $\lambda = 1.5$ in the axial direction and twisted by 180°. The following graph illustrates the torsion bc.
top_pts = mesh.points[:, 2] == mesh.bounds[5](click to toggle)
top_surf = mesh.extract_points(top_pts, False, False).delaunay_2d()
fig = ot.plot.contourf(top_surf, ot.variables.displacement, figsize=(8, 6), fontsize=14)
Let’s plot the result.
pl = pv.Plotter()(click to toggle)
pl = pv.Plotter()
pl.camera_position = (-0.5, -0.5, 0.4)
pl.show_axes()
pl.reset_camera()
pl.show()
2025-10-28 16:36:23.354 (   5.308s) [    7FBC6D669400]vtkXOpenGLRenderWindow.:1416  WARN| bad X server connection. DISPLAY=
Convergence
What we’re more interested in, is the convergence behaviour over time. The large deformations were applied in only 5 load steps to challenge the algorithm.
log_file_raw = logparser.parse_file(f"{out_dir}/out.txt")(click to toggle)
log_df = pd.DataFrame(log_file_raw)
for ts in range(1, 6):
    dxs = log_df[log_df["time_step"] == ts]["dx"].dropna().to_numpy()
    slopes = np.log10(dxs)[1:] / np.log10(dxs)[:-1]
    # not checking slope of last ts (below quadratic due to precision limit)
    assert np.all(slopes[:-1] > 1.9)
fig, ax = plt.subplots(dpi=120)(click to toggle)
ts1_df = log_df[log_df["time_step"] == 1]
its, dxs = ts1_df[["iteration_number", "dx"]].dropna().to_numpy(float).T
ax.plot(its, dxs, "-o", label="timestep 1", lw=3)
offset = 3 - np.log2(-np.log10(dxs[2]))  # to touch the data at dx(it=3)
quad_slope = 10 ** -(2 ** (its - offset))
ax.plot(its, quad_slope, "--C1", lw=3, label="quadratic convergence")
ax.axhline(1e-13, ls="-.", color="k", label="convergence criterion")
ax.set_xscale("function", functions=(lambda x: 2**x, lambda x: np.log10(x - 2)))
ax.set_yscale("log")
ax.set_xlim([1, 5])
ax.set_xticks(its)
ax.set_xlabel("iteration number")
ax.set_ylabel("$|| \\Delta \\vec{u}$ || / m")
ax.legend()
We observe quadratic convergence in the proximity of the solution supporting the implementation of the geometric stiffness matrix. The last iteration converges slightly less then quadratic since we reach the numerical precision limit at this point.
Generated with Hugo 0.147.9 in CI job 638941 | Last revision: March 2, 2023
