# modules…
(click to toggle)
# modules
import time
import matplotlib.tri as tri
import vtk
import vtuIO
from scipy.special import exp1
from vtk.util.numpy_support import vtk_to_numpy# settings…
(click to toggle)
# settings
path = "./"
fig_dir = "./figures/"
prj_name = "axisym_theis"
prj_file = f"{prj_name}.prj"
pvd_name = "liquid_pcs"
vtu_name = "axisym_theis.vtu"
title = "H process: Theis solution (Pumping well)"
out_dir.mkdir(parents=True, exist_ok=True)Problem description
Theis` problem examines the transient lowering of the water table induced by a pumping well. The assumptions required by the Theis solution are:
The aquifer
The well
The analytical solution of the drawdown as a function of time and distance is expressed by
$$ s(r,t) = h_0 - h(r,t) = \frac{Q}{4\pi T}W(u), \quad \mathrm{where}\quad u = \frac{r^2S}{4Tt}. $$where
The Well Function, $W(u)$ is the exponential integral, $E_1(u).$ $W(u)$ is defined by an infinite series:
$$ W(u) = - \gamma - \ln u + \sum_{k=1}^\infty \frac{(-1)^{k+1} u^k}{k \cdot k!} $$where
For practical applications an approximation to the exponential integral is used often:
$$W(u) \approx -\gamma - \ln u$$This results in an expression for $s(r,t)$ known as the Jacob equation:
$$ s(r,t) = -\frac{Q}{4\pi T}\left(\gamma + \ln u \right). $$For more details we refer to Srivastava and Guzman-Guzman (1998).
# source: https://scipython.com/blog/linear-and-non-linear-fitting-of-the-theis-equation/…
(click to toggle)
def calc_u(r, S, T, t):
"""Calculate and return the dimensionless time parameter, u."""
return r**2 * S / 4 / T / t
def theis_drawdown(t, S, T, Q, r):
"""Calculate and return the drawdown s(r,t) for parameters S, T.
This version uses the Theis equation, s(r,t) = Q * W(u) / (4.pi.T),
where W(u) is the Well function for u = Sr^2 / (4Tt).
S is the aquifer storage coefficient,
T is the transmissivity (m2/day),
r is the distance from the well (m), and
Q is the pumping rate (m3/day).
u = calc_u(r, S, T, t)
return Q / 4 / np.pi / T * exp1(u)Q = 2000 # Pumping rate from well (m3/day)…
(click to toggle)
r = 10 # Distance from well (m)
# Time grid, days.
t = np.array([1, 2, 4, 8, 12, 16, 20, 30, 40, 50, 60, 70, 80, 90, 100])
# Calculate some synthetic data to fit.
S, T = 0.0003, 1000
s = theis_drawdown(t, S, T, Q, r)
# Plot the data
titlestring = "Theis: Analytical solution"
plt.title(titlestring)
plt.plot(t, s, label="r = " + str(r) + " m")
plt.xlabel(r"$t\;/\;\mathrm{days}$")
plt.ylabel(r"$s\;/\;\mathrm{m}$")
plt.legend()
plt.grid()
# Recalculation from days in sec…
(click to toggle)
Q = 0.016 # Pumping rate from well (m3/s)
t = 864000 # Time in s.
##r = np.array([0.5, 1, 2, 4, 8, 12, 16, 20, 25, 30, 35, 40])
r = np.arange(1, 41, 1)
##print(r)
S = 0.001
T = 9.2903e-4
s = s - 5 # reference head
# Plot the data
plt.plot(r, s, label="t = " + str(t) + " days")
plt.xlabel(r"$r\;/\mathrm{m}$")
plt.ylabel(r"$hydraulic head\;/\;\mathrm{m}$")
plt.legend()
plt.grid()
Numerical solution
mesh = pv.read(vtu_name)…
(click to toggle)
print("inspecting vtu-file")
print(mesh)inspecting vtu-file
UnstructuredGrid (0x7fd56d027fa0)
N Cells: 354
N Points: 476
X Bounds: 3.048e-01, 3.048e+02
Y Bounds: 0.000e+00, 1.000e+00
N Arrays: 1
print("inspecting mesh and initial conditions")…
(click to toggle)
# file
reader = vtk.vtkXMLUnstructuredGridReader()
reader.SetFileName(vtu_name)
reader.Update() # Needed because of GetScalarRange
data = reader.GetOutput()
pressure = data.GetPointData().GetArray("OGS5_pressure")
# points
points = data.GetPoints()
npts = points.GetNumberOfPoints()
x = vtk_to_numpy(points.GetData())
triang = tri.Triangulation(x[:, 0], x[:, 1])
# plt.triplot(triang, 'go-', lw=1.0)
plt.triplot(triang, lw=0.2)
plt.tricontour(triang, pressure, 16)inspecting mesh and initial conditions
<matplotlib.tri._tricontour.TriContourSet at 0x7fd56f47d6a0>
Running OGS
# run ogs…
(click to toggle)
# run ogs
t0 = time.time()
print("run ogs")
print(f"ogs {prj_file} > log.txt")
run(f"ogs {prj_file} -o {out_dir} > {out_dir}/log.txt", shell=True, check=True)
tf = time.time()
print("computation time: ", round(tf - t0, 2), " s.")run ogs
ogs axisym_theis.prj > log.txt
computation time: 0.45 s.
Spatial Profiles
# Read simulation results…
(click to toggle)
pvdfile = vtuIO.PVDIO(f"{out_dir}/{pvd_name}.pvd", dim=2)
xaxis = [(i, 0, 0) for i in np.linspace(start=1.0, stop=40, num=40)]
r_x = np.array(xaxis)[:, 0]
time = [8.64, 86.4, 1728, 24192, 172800, 604800, 864000]
pressure_xaxis_t = pvdfile.read_set_data(
t, "OGS5_pressure", data_type="point", pointsetarray=xaxis
plt.plot(r_x, pressure_xaxis_t, "x", label="OGS5, t = 1728 sec")
for t in time:
t, "pressure", data_type="point", pointsetarray=xaxis
plt.plot(r_x, pressure_xaxis_t, label="t = " + str(t) + " sec")
titlestring = "Theis: Numerical solution"
plt.legend()
plt.grid()
# plt.savefig("theis.png")
time = [864000]…
(click to toggle)
time = [864000]
# plot configuration
##plt.rcParams['figure.figsize'] = (16, 6)
##plt.rcParams['font.size'] = 12
##fig1, (ax1, ax2) = plt.subplots(1, 2)
fig, ax = plt.subplots(ncols=2, figsize=(12, 4))
titlestring = "Theis: Comparison analytical and numerical solution"
ax[0].set_title(titlestring)
ax[0].set_xlim(0, 40)
ax[0].plot(r_x, pressure_xaxis_t, "x", label="numerical solution (ogs6)")
ax[0].plot(r, s, label="analytical solution")
ax[0].set_xlabel(r"$radius\;/\;\mathrm{m}$")
ax[0].set_ylabel(r"$hydraulic head\;/\;\mathrm{m}$")
ax[0].grid()
ax[0].legend()
##diff = np.setdiff1d(s,pressure_xaxis_t,assume_unique=False)
##print(diff)
titlestring = "Difference between analytical and numerical solutions"
caption = "Differences are due to different boundary conditions"
ax[1].set_title(titlestring)
ax[1].set_xlim(0, 40)
ax[1].plot(r, s - pressure_xaxis_t, label="")
ax[1].set_xlabel(r"$radius\;/\;\mathrm{m}$")
ax[1].set_ylabel(r"$diff\;/\;\mathrm{m}$")
ax[1].grid()
ax[1].text(5, 0.7, caption, ha="left")
##plt.savefig("theis-ana+num.png")
OGS links
Credits
This article was written by Wenqing Wang, Olaf Kolditz. If you are missing something or you find an error please let us know.
in CI job 638941
Last revision: August 24, 2022
