Hydraulic Fracturing in the Toughness-Dominated Regime
Under the toughness-dominated regime without leak-off, the fluid viscosity dissipation is negligible compared to the energy released for fracture surface formation (Detournay et al., 2016). Therefore, in this regime, we can neglect the pressure loss within the fracture and use the Sneddon solution for crack opening (Bourdin et al., 2012, Sneddon et al., 1969) to determine the pressure and length evolution.
The work of the pressure force is as follows:
$$ \begin{equation} \mathcal{W}(R) =\frac{2 p^2 a^2}{E'}. \end{equation} $$
Applying Clapeyron’s theorem, the elastic energy can be determined as
$$ \begin{equation} \mathcal{E}(R) =-\frac{\pi p^2 a^2}{E'}, \end{equation} $$
and the energy release rate with respect to the crack length $a$ propagating along the initial inclination is
$$ \begin{equation} G(R) = - \frac{\partial \mathcal{E}}{\partial (2 a)} = \frac{\pi p^2 a}{E'}. \end{equation} $$
Griffith's criterion (Griffith et al., 1920) states that the fracture propagates when $G=G_c$ and the critical volume for crack propagation is $V_c := \sqrt{\dfrac{4 \pi G_c a^3}{E' }}$ in a quasi-static volume control setting (the fracture propagation is always unstable with pressure control).
The evolution of the corresponding pressure and fracture length
$$ \begin{equation} p(V) = \begin{cases} \dfrac{E' V}{2 \pi a_0^2} &\text{for} V < V_c \\ \left[ \dfrac{2 E' G_c^2}{\pi V} \right] ^{\frac{1}{3}}&\text{for} V \geq V_c, \end{cases} \end{equation} $$ $$ \begin{equation} a(V) = \begin{cases} a_0 & V < V_c \\ \left[ \dfrac{E' V^2}{4 \pi G_c} \right ] ^{\frac{1}{3}} & V \geq V_c. \end{cases} \end{equation} $$
Problem Description
Based on Sneddon's solution (Sneddon et al., 1969), we verified the model with plane-strain hydraulic fracture propagation in a toughness-dominated regime. In an infinite 2D domain, the problem was solved with a line fracture $[-a_0, a_0] \times \{0\}$ ($a_0$ = 0.05). We considered a large finite domain $[-40a_0,40a_0] \times [-40a_0,40a_0]$ to account for the infinite boundaries in the closed-form solution. The effective size of an element, $h$, is $1\times10^{-2}$.
Schematic view of hydraulic fracturing problem and Boundary conditions
Schematic view of hydraulic fracturing problem and Boundary conditions.
  • In order to have the hydraulic fracturing in the toughness dominated-regime, add, $\texttt{propagating}$ in the project file.
  • Yoshioka et al., 2019 provides additional information on the implementation, use of real material properties, and rescaling of the phase-field energy functional.
Input Data
Taking advantage of the linearity of the system, the simulations were run with the dimensionless properties listed in the Table below.
Name Value Symbol
Young’s modulus 1 $E$
Poisson’s ratio 0.15 $\nu$
Fracture toughness 1 $G_{c}$
Length 4 $L$
Height 4 $H$
Initial crack length 0.1 $2a_0$
import math(click to toggle)
import math
import re
import time
import gmsh
pi = math.pi
plt.rcParams["text.usetex"] = True
E = 1.0(click to toggle)
E = 1.0
nu = 0.15
Gc = 1.0
h = 0.01
a0 = 0.05  # half of the initial crack length
phasefield_model = "AT1"  # AT1/AT2
Output Directory and Project File
# file's name(click to toggle)
# file's name
prj_name = "Kregime_Propagating.prj"
meshname = "mesh_full_pf"
if not out_dir.exists():
    out_dir.mkdir(parents=True)
Mesh Generation
def mesh_generation(lc, lc_fine):(click to toggle)
    L = 4.0  # Length
    H = 4.0  # Height
    gmsh.initialize()
    gmsh.model.add("rectangle")
    # Dimensions
    dim0 = 0
    dim1 = 1
    dim2 = 2
    # Points
    # Lines
    # Line loops
    gmsh.model.geo.synchronize()
    # Prepare structured grid
    # Physical groups
    P1 = gmsh.model.addPhysicalGroup(dim0, [1])
    gmsh.model.setPhysicalName(dim0, P1, "P1")
    P2 = gmsh.model.addPhysicalGroup(dim0, [2])
    gmsh.model.setPhysicalName(dim0, P2, "P2")
    gmsh.write(output_file)
    gmsh.finalize()
Pre-Processing
def pre_processing(h, a0):(click to toggle)
    mesh = pv.read(f"{out_dir}/mesh_full_pf_domain.vtu")
    pv.set_plot_theme("document")
        if (
            phase_field[node_id] = 0.0
Run the Simulation
pv.set_plot_theme("document")(click to toggle)
def Hydraulic_Fracturing_Toughness_Dominated_numerical(h, phasefield_model):
    # mesh properties
    ls = 2 * h
    filename = f"results_h_{h:0.4f}_{phasefield_model}"
    mesh_generation(0.1, h)
        pv.save_meshio(f"{out_dir}/mesh_full_pf_{name}.vtu", mesh)
    %cd {out_dir}
    run(
        "identifySubdomains -f -m mesh_full_pf_domain.vtu -- mesh_full_pf_physical_group_*.vtu",
        shell=True,
        check=True,
    %cd -
        input_file=prj_name,
        MKL=True,
        args=f"-o {out_dir}",
    # run simulation with ogs
    t0 = time.time()
    run(
        f"ogs {out_dir}/{prj_name} -o {out_dir} > {out_dir}/log.txt",
        shell=True,
        check=True,
    tf = time.time()
Info    : Meshing 1D...
Info    : Done meshing 1D (Wall 0.000400204s, CPU 0.000692s)
Info    : Meshing 2D...
Info    : [  0%] Blossom recombination completed (Wall 0.323561s, CPU 0.323478s): 7878 quads, 0 triangles, 0 invalid quads, 0 quads with Q < 0.1, avg Q = 0.793024, min Q = 0.371315
Info    : Done meshing 2D (Wall 0.475199s, CPU 0.474977s)
Info    : Writing '/var/lib/gitlab-runner/builds/vZ6vnZiU/1/ogs/build/release-petsc/Tests/Data/PhaseField/Kregime_Propagating_jupyter_notebook/Kregime_Propagating_jupyter/mesh_full_pf.msh'...
Info    : Done writing '/var/lib/gitlab-runner/builds/vZ6vnZiU/1/ogs/build/release-petsc/Tests/Data/PhaseField/Kregime_Propagating_jupyter_notebook/Kregime_Propagating_jupyter/mesh_full_pf.msh'
[2025-04-11 09:24:29.165] [ogs] [info] Mesh reading time: 0.0303692 s
[2025-04-11 09:24:29.166] [ogs] [info] MeshNodeSearcher construction time: 0.000515946 s
[2025-04-11 09:24:29.166] [ogs] [info] identifySubdomainMesh(): identifySubdomainMeshNodes took 1.448e-05 s
[2025-04-11 09:24:29.166] [ogs] [info] There is already a 'bulk_node_ids' property present in the subdomain mesh 'mesh_full_pf_physical_group_Bottom' and it is equal to the newly computed values.
[2025-04-11 09:24:29.167] [ogs] [info] identifySubdomainMesh(): identifySubdomainMeshElements took 0.00100331 s
[2025-04-11 09:24:29.168] [ogs] [info] identifySubdomainMesh(): identifySubdomainMeshNodes took 0.00117562 s
[2025-04-11 09:24:29.168] [ogs] [info] There is already a 'bulk_node_ids' property present in the subdomain mesh 'mesh_full_pf_physical_group_Computational_domain' and it is equal to the newly computed values.
[2025-04-11 09:24:29.175] [ogs] [info] identifySubdomainMesh(): identifySubdomainMeshElements took 0.00626513 s
[2025-04-11 09:24:29.175] [ogs] [info] identifySubdomainMesh(): identifySubdomainMeshNodes took 5.33e-06 s
[2025-04-11 09:24:29.175] [ogs] [info] There is already a 'bulk_node_ids' property present in the subdomain mesh 'mesh_full_pf_physical_group_Left' and it is equal to the newly computed values.
[2025-04-11 09:24:29.176] [ogs] [info] identifySubdomainMesh(): identifySubdomainMeshElements took 0.000693352 s
[2025-04-11 09:24:29.176] [ogs] [info] identifySubdomainMesh(): identifySubdomainMeshNodes took 4.5e-07 s
[2025-04-11 09:24:29.176] [ogs] [info] There is already a 'bulk_node_ids' property present in the subdomain mesh 'mesh_full_pf_physical_group_P1' and it is equal to the newly computed values.
[2025-04-11 09:24:29.176] [ogs] [info] identifySubdomainMesh(): identifySubdomainMeshElements took 0.000633729 s
[2025-04-11 09:24:29.176] [ogs] [info] identifySubdomainMesh(): identifySubdomainMeshNodes took 5.2e-07 s
[2025-04-11 09:24:29.176] [ogs] [info] There is already a 'bulk_node_ids' property present in the subdomain mesh 'mesh_full_pf_physical_group_P2' and it is equal to the newly computed values.
[2025-04-11 09:24:29.177] [ogs] [info] identifySubdomainMesh(): identifySubdomainMeshElements took 0.000630699 s
[2025-04-11 09:24:29.177] [ogs] [info] identifySubdomainMesh(): identifySubdomainMeshNodes took 6.59e-06 s
[2025-04-11 09:24:29.177] [ogs] [info] There is already a 'bulk_node_ids' property present in the subdomain mesh 'mesh_full_pf_physical_group_Right' and it is equal to the newly computed values.
[2025-04-11 09:24:29.178] [ogs] [info] identifySubdomainMesh(): identifySubdomainMeshElements took 0.00063815 s
[2025-04-11 09:24:29.178] [ogs] [info] identifySubdomainMesh(): identifySubdomainMeshNodes took 5.741e-06 s
[2025-04-11 09:24:29.178] [ogs] [info] There is already a 'bulk_node_ids' property present in the subdomain mesh 'mesh_full_pf_physical_group_Top' and it is equal to the newly computed values.
[2025-04-11 09:24:29.178] [ogs] [info] identifySubdomainMesh(): identifySubdomainMeshElements took 0.00063995 s
[2025-04-11 09:24:29.178] [ogs] [info] identifySubdomains time: 0.0124293 s
[2025-04-11 09:24:29.198] [ogs] [info] writing time: 0.0191969 s
[2025-04-11 09:24:29.198] [ogs] [info] Entire run time: 1.25207 s
/var/lib/gitlab-runner/builds/vZ6vnZiU/1/ogs/ogs/Tests/Data/PhaseField/Kregime_Propagating_jupyter_notebook
>>> OGS terminated execution  <<< Elapsed time:  382.0  s.
Post-Processing
Analytical Solution for the Evolution of Fracture Length and Pressure
def Analytical_solution(phasefield_model, h):(click to toggle)
    v = np.linspace(1e-10, 0.3, 31)
    pres = np.linspace(0, 1.0, 31)
    length = np.linspace(0, 1.0, 31)
    ls = 2 * h
    # Effective Gc and a for AT1/A2
    if phasefield_model == "AT1":
        Gc_ref = Gc * (3 * h / 8.0 / ls + 1.0)
        Gc_ref = Gc * (h / (2.0 * ls) + 1.0)
    Eprime = E / (1 - nu**2)
    V_c = (4 * pi * Gc_ref * a_eff**3 / Eprime) ** 0.5
    P_c = (Eprime * Gc_ref / (pi * a_eff)) ** 0.5
    for i in range(len(v)):
        if v[i] < V_c:
            pres[i] = Eprime * v[i] / (2 * pi * a_eff**2) / P_c
            length[i] = a_eff
            pres[i] = (2 * Eprime * Gc_ref**2 / (pi * v[i])) ** 0.333333 / P_c
            length[i] = (Eprime * v[i] ** 2 / (4 * pi * Gc_ref)) ** 0.333333
    return v, pres, length, Gc_ref, P_c
fluidVolume_analytical = Analytical_solution(phasefield_model, h)[0]
pressure_analytical = Analytical_solution(phasefield_model, h)[1]
length_analytical = Analytical_solution(phasefield_model, h)[2]
Gc_ref = Analytical_solution(phasefield_model, h)[3]
P_c = Analytical_solution(phasefield_model, h)[4]
Phase Field Versus Analytical Solution for Fracture Length and Pressure Evolution
In phase field approach, we can retrieve the crack length $a$ as:
$$ \begin{equation} a = \dfrac{\displaystyle \int_\Omega \frac{G_c}{4 c_n} \left(\frac{(1-v)^n}{\ell}+ \ell |\nabla v|^2\right)\,\mathrm{d} \Omega }{G_c \left( \dfrac{h}{4 c_n \ell} + 1 \right)}. \end{equation} $$
where $n=1$ corresponds to $\texttt{AT}_1$ ($c_n = 2/3$) and $n=2$ to $\texttt{AT}_2$ ($c_n = 1/2$).
plt.subplots(figsize=(12, 4))(click to toggle)
plt.subplot(1, 2, 1)
fluid_volume = []
surface_energy = []
# Open the file for reading
with (out_dir / "log.txt").open() as fd:
    # Iterate over the lines
    for _i, line in enumerate(fd):
        match_surface_energy = re.search(
            r"""Surface energy: (\d+\.\d*) Pressure work: (\d+\.\d*)  at time: (\d+\.\d*)""",
            line,
        if match_surface_energy:
            surface_energy.append(float(match_surface_energy.group(1)))
            fluid_volume.append(float(match_surface_energy.group(3)))
plt.grid(linestyle="dashed")
plt.xlabel("Volume")
plt.ylabel("Crack length")
plt.plot(fluidVolume_analytical, length_analytical, "black", label="Closed form")
plt.plot(
    fluid_volume,
    np.array(surface_energy[:]) / Gc_ref / 2,
    "bo",
    fillstyle="none",
    label="Phase-field",
plt.subplot(1, 2, 2)
fluid_volume = []
pressure = []
        match_pressure = re.search(
            r"""Pressure: (\d+\.\d*) at time: (\d+\.\d*)""", line
        if match_pressure:
            fluid_volume.append(float(match_pressure.group(2)))
            pressure.append(float(match_pressure.group(1)))
plt.ylabel("$p_f/p_c$")
plt.plot(fluidVolume_analytical, pressure_analytical, "black", label="Closed form")
plt.plot(
    np.array(fluid_volume[:]),
    np.array(pressure[:]) / P_c,
    "g<",
    fillstyle="none",
plt.plot(
    fluidVolume_analytical[1:],
        abs(length_analytical[1:] - np.array(surface_energy[:]) / (2 * Gc_ref))
        / (np.array(surface_energy[:]) / (2 * Gc_ref))
    * 100,
    "-.ob",
    fillstyle="none",
    label="Closed form",
plt.ylim([0.0, 10])
plt.ylabel(
    r"$\frac{|a_\mathrm{num}-{a}_\mathrm{ana}|}{{a}_\mathrm{num}}\times 100\%$",
    fontsize=14,
plt.plot(
    (abs(pressure_analytical[1:] - np.array(pressure[:]) / P_c) / pressure[:]) * 100,
    "-.<g",
    fillstyle="none",
plt.ylim([0.0, 10])
plt.ylabel(
    r"$\frac{|p_\mathrm{num}-{p}_\mathrm{ana}|}{{p}_\mathrm{num}}\times 100\%$",
    fontsize=14,
In order to reduce computation time, we perform the simulation with a coarse mesh; the results for the $\texttt{AT}_1$ Model with a mesh size of $h=0.001$ are provided below.
$\texttt{AT}_1$ Model:
Phase field versus analytical solution for fracture length and pressure evolution
Phase field versus analytical solution for fracture length and pressure evolution, $\texttt{AT}_1$.
Error between the Phase field and analytical solution for fracture length and pressure evolution.
Error between the Phase field and analytical solution for fracture length and pressure evolution, $\texttt{AT}_1$.
Hydraulic Fracturing Animation (Using Phase Field Approach)
filename = f"results_h_{h:0.4f}_{phasefield_model}"(click to toggle)
reader = pv.get_reader(f"{out_dir}/" + filename + ".pvd")
plotter = pv.Plotter(shape=(1, 2), border=False)
plotter.open_gif(f"{out_dir}/Kregime_Propagating.gif")
    mesh = reader.read()[0]
    sargs = {
        "title": "Phase field",
        "title_font_size": 16,
        "label_font_size": 12,
        "n_labels": 5,
        "position_x": 0.25,
        "position_y": 0.15,
        "fmt": "%.1f",
        "width": 0.5,
    clim = [0, 1.0]
    xs = mesh.points[:, 0]
    ys = mesh.points[:, 1]
    plotter.clear()
    plotter.add_mesh(
        mesh,
        scalars=pf,
        show_scalar_bar=True,
        colormap="coolwarm",
        clim=clim,
        scalar_bar_args=sargs,
        lighting=False,
    plotter.add_text(f"Time: {time_value:0.02f}", color="black")
    plotter.view_xy()
    plotter.write_frame()
plotter.close()
Phase Field Profile at Last Time Step
mesh = reader.read()[0](click to toggle)
clim = [0, 1.0]
sargs = {
    "n_labels": 5,
    "position_x": 0.25,
    "position_y": 0.0,
    "fmt": "%.1f",
    "width": 0.5,
plotter.add_mesh(
    mesh,
    scalars=pf,
    show_edges=False,
    clim=clim,
    lighting=False,
plotter.view_xy()
plotter.camera.zoom(1.5)
plotter.window_size = [1000, 500]
Widget(value='<iframe src="http://localhost:44971/index.html?ui=P_0x7a78a8f34320_31&reconnect=auto" class="pyv…
[1] Detournay, Emmanuel. Mechanics of hydraulic fractures. Annual review of fluid mechanics 48 (2016): 311-339.
[2] Bourdin, Blaise, Chukwudi Chukwudozie, and Keita Yoshioka. A variational approach to the numerical simulation of hydraulic fracturing. In SPE annual technical conference and exhibition. OnePetro, 2012.
[4] Griffith, Alan Arnold. VI. The phenomena of rupture and flow in solids. Philosophical transactions of the royal society of london. Series A, containing papers of a mathematical or physical character 221, no. 582-593 (1921): 163-198.
[5] Yoshioka, Keita, Francesco Parisio, Dmitri Naumov, Renchao Lu, Olaf Kolditz, and Thomas Nagel. Comparative verification of discrete and smeared numerical approaches for the simulation of hydraulic fracturing. GEM-International Journal on Geomathematics 10, no. 1 (2019): 1-35.
Generated with Hugo 0.122.0 in CI job 545140 | Last revision: March 3, 2023
