Static fracture opening under a constant pressure
Consider a line fracture $[-a_0, a_0] \times \{0\}$ ($a_0$ = 0.1) with no external loading and an internal fluid pressure of $p=1$ was applied to the fracture surfaces. The results are compared to the analytical solution (Sneddon et al., 1969) for the fracture half-opening: \begin{eqnarray} u(x,0) = \frac{2 p a_0}{ E’} \sqrt{1-(x/a_0)^2} , \label{eq:sneddon_2D_static} \end{eqnarray}
where $u$ is the displacement $E'$ is the plane strain Young’s modulus ($E' = E/(1-\nu^2)$) with $\nu$ is Poisson`s ratio, $p$ is the fluid pressure inside the fracture. To account for the infinite boundaries in the closed-form solution, we considered a large finite domain $ [-10a_o,10a_o] \times [-10a_o,10a_o]$. The effective element size, $h$, is $1\times10^{-2}$.
Schematic view of Sneddon problem and Boundary conditions
Schematic view of Sneddon problem and Boundary conditions.
  • In order to have a static pressurized fracture, add, $\texttt{static}$ in the project file. It’s important to note that static pressurized fracture implementation assumes $p=1$. Yoshioka et al., 2019 discussed using real material properties and rescaling the phase-field energy functional.
Input data
The material and geometrical properties are listed in the Table below. It’s worth noting that the properties are dimensionless and scaled.
Name Value Symbol
Young’s modulus 1 $E$
Poisson’s ratio 0.15 $\nu$
Fracture toughness 1 $G_{c}$
Pressure 1 $p$
Length 2 $L$
Height 2 $H$
Initial crack length 0.2 $2a_0$
import math(click to toggle)
import math
import time
import gmsh
(click to toggle)
pi = math.pi
plt.rcParams["text.usetex"] = True
E = 1.0(click to toggle)
E = 1.0
nu = 0.15
Gc = 1.0
P = 1.0
h = 0.01
Orientation = 0
a0 = 0.1  # half of the initial crack length
n_slices = (
    2 * (round(3.0 * a0 / h)) + 1
)  # number of slices for calcute width of fracture
phasefield_model = "AT1"
h_list = [0.01]  # list of mesh sizes (h)
# h_list =[0.01, 0.005, 0.0025]  # list of mesh sizes (h), for mesh sensitivity
Output directory and project file
# file's name(click to toggle)
# file's name
prj_name = "Kregime_Static.prj"
meshname = "mesh_full_pf"
if not out_dir.exists():
    out_dir.mkdir(parents=True)
Mesh generation
def mesh_generation(lc, lc_fine):(click to toggle)
    L = 4.0  # Length
    H = 4.0  # Height
    gmsh.initialize()
    gmsh.model.add("rectangle")
    # Dimensions
    dim1 = 1
    dim2 = 2
    # Points
    # Lines
    # Line loops
    gmsh.model.geo.synchronize()
    # Prepare structured grid
    # Physical groups
    gmsh.write(output_file)
    gmsh.finalize()
Pre process
def pre_processing(h, a0):(click to toggle)
    mesh = pv.read(f"{out_dir}/domain.vtu")
    pv.set_plot_theme("document")
        if (
            phase_field[node_id] = 0.0
Run the simulation
pv.set_plot_theme("document")(click to toggle)
def sneddon_numerical(h):
    # mesh properties
    ls = 2 * h
    filename = f"results_h_{h:0.4f}"
    mesh_generation(0.1, h)
        pv.save_meshio(f"{out_dir}/{name}.vtu", mesh)
        input_file=prj_name,
        MKL=True,
        args=f"-o {out_dir}",
    gml_file = Path("./Kregime_Static.gml").resolve()
    # run simulation with ogs
    t0 = time.time()
    run(
        shell=True,
        check=True,
    tf = time.time()
    print(
        ">>> OGS terminated execution  <<< Elapsed time: ",
        round(tf - t0, 2),
        " s.",
for h_j in h_list:
    sneddon_numerical(h=h_j)
Info    : Meshing 1D...
Info    : Done meshing 1D (Wall 0.000489639s, CPU 0.000794s)
Info    : Meshing 2D...
Info    : [  0%] Blossom recombination completed (Wall 0.400664s, CPU 0.402018s): 7878 quads, 0 triangles, 0 invalid quads, 0 quads with Q < 0.1, avg Q = 0.793024, min Q = 0.371315
Info    : Done meshing 2D (Wall 0.600875s, CPU 0.602421s)
Info    : Writing '/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/PhaseField/kregime_jupyter_notebook/Kregime_Static_jupyter/mesh_full_pf.msh'...
Info    : Done writing '/var/lib/gitlab-runner/builds/e3EQ9HiK/0/ogs/build/release-petsc/Tests/Data/PhaseField/kregime_jupyter_notebook/Kregime_Static_jupyter/mesh_full_pf.msh'
>>> OGS terminated execution  <<< Elapsed time:  6.39  s.
Post processing
# As a post-process, we calculate the fracture opening.(click to toggle)
def width_calculation(filename):
    reader = pv.get_reader(f"{out_dir}/{filename}.pvd")
    # Active the results of last time step
    reader.set_active_time_value(reader.time_values[-1])
    mesh = reader.read()[0]
    # define grad d
    mesh_d = mesh.compute_derivative(scalars="phasefield")
    mesh_d["gradient"]
    def gradients_to_dict(arr):
        """A helper method to label the gradients into a dictionary."""
        keys = np.array(
            ["grad_dx", "grad_dy", "grad_dz", "grad_dx", "grad_dy", "grad_dz"]
        keys = keys.reshape((2, 3))[:, : arr.shape[1]].ravel()
        return dict(zip(keys, mesh_d["gradient"].T))
    gradients_d = gradients_to_dict(mesh_d["gradient"])
    mesh.point_data.update(gradients_d)
    # define width at nodes
    grad_dx = mesh.point_data["grad_dx"]
    grad_dy = mesh.point_data["grad_dy"]
    num_points = disp.shape
    Wnode = np.zeros(num_points[0])
        u_x = disp[i][0]
        u_y = disp[i][1]
        gd_x = grad_dx[i]
        gd_y = grad_dy[i]
        Wnode[i] = 0.5 * (u_x * gd_x + u_y * gd_y)
    mesh.point_data["Wnode"] = Wnode
    # Normalize the vector
    normal = [np.cos(Orientation), np.sin(Orientation), 0]
    # Make points along that vector for the extent of your slices
    point_a = mesh.center + np.array([1.5 * a0, 0, 0])
    point_b = mesh.center + np.array([-1.5 * a0, 0, 0])
    dist_a_b = ((point_b[0] - point_a[0]) ** 2 + (point_b[1] - point_a[1]) ** 2) ** 0.5
    # Define the line/points for the slices
    line = pv.Line(point_a, point_b, n_slices)
    width_line = np.zeros(len(line.points))
    r_i = np.zeros(len(line.points))
    # Generate all of the slices
    slices = pv.MultiBlock()
    for i, point in enumerate(line.points):
        slices.append(mesh.slice(normal=normal, origin=point))
        slice_mesh = mesh.slice(normal=normal, origin=point)
        y_slice = slice_mesh.points[:, 1]
        Wnode_slice = slice_mesh.point_data["Wnode"]
        width_i = np.trapz(Wnode_slice, x=y_slice)  # noqa: NPY201
        if width_i >= 0:
            width_line[i] = width_i
        r_i[i] = (
            (point[0] - point_a[0]) ** 2 + (point[1] - point_a[1]) ** 2
        ) ** 0.5 - dist_a_b / 2
    return r_i, width_line
Sneddon
def sneddon(h, ls, phasefield_model):(click to toggle)
    # Effective a for AT1/A2
    if phasefield_model == "AT1":
    x = np.linspace(-1.0 * a_eff, a_eff, 40)
    uy = []
    for i in range(len(x)):
        uy.append(
            2 * a_eff * (1 - nu**2) * P / E * math.sqrt(1.0 - ((x[i]) / (a_eff)) ** 2)
    return x, uy, a_eff
Opening profile
color = ["-.k", "ko", "-.r", "ro", "-.b", "bo", "-.g", "go"](click to toggle)
Label = ["Closed form solution", "VPF-FEM"]
lineWIDTH = [1.5, 1.5, 1.5]
for j, h_j in enumerate(h_list):
    r_i_num = []
    width_line_num = []
    filename = f"results_h_{h_j:0.4f}"
    print(filename)
    r_i_num = width_calculation(filename)[0]
    width_line_num = width_calculation(filename)[1]
    ls = 2 * h_j
    x_Sneddon = sneddon(h_j, ls, phasefield_model)[0]
    uy_Sneddon = sneddon(h_j, ls, phasefield_model)[1]
    a_eff_Sneddon = sneddon(h_j, ls, phasefield_model)[2]
    plt.plot(
        np.array(x_Sneddon[:]),
        np.array(uy_Sneddon[:]),
        color[2 * j],
        fillstyle="none",
        markersize=0,
        linewidth=lineWIDTH[0],
        label=f"Closed form solution - $h= ${h_j:0.4f}",
    plt.plot(
        np.array(r_i_num[:]),
        np.array(width_line_num[:]),
        color[2 * j + 1],
        fillstyle="none",
        markersize=6,
        linewidth=lineWIDTH[1],
        label=f"VPF - $h =${h_j:0.4f}",
plt.rcParams["figure.figsize"] = [40, 20]
plt.rcParams["figure.dpi"] = 1600
plt.ylabel("$w_n$ [m]", fontsize=14)
plt.xlabel("$r$ [m]", fontsize=14)
plt.grid(linestyle="dashed")
plt.title(f"{phasefield_model}")
legend = plt.legend(bbox_to_anchor=(1.04, 1), loc="upper left")
results_h_0.0100
/tmp/ipykernel_3716448/3703761407.py:62: DeprecationWarning: `trapz` is deprecated. Use `trapezoid` instead, or one of the numerical integration functions in `scipy.integrate`.
To decrease computing time, we perform the simulation with an one coarse mesh; Mesh sensitivity can be investigated in order to assess the convergence of the opening profile for various mesh discretizations. Following are the mesh sensivity results for for Models $\texttt{AT}_1$ and $\texttt{AT}_2$ ($h=0.01,~0.005,~\text{and} ~0.0025$ m.)
Crack opening profiles of  VPF ($\texttt{AT}_1$) with different mesh sizes compared against the Sneddon solution.
Crack opening profiles of  VPF ($\texttt{AT}_2$) with different mesh sizes compared against the Sneddon solution.
Our mesh size sensitivity study shows even with coarse mesh. The results away from crack tips agree well with the Sneddon solution. Using finer mesh demonstrates that the opening along the whole crack length is accurate compared with the closed-form solution.
It’s worth noting that we estimate width as part of post-processing (using the line integral and a given crack normal vector). However, near crack tips the crack normal vector is different to the given normal vector, so the width values are inaccurate near crack tips. For the sake of simplicity, we neglect determining the normal crack vector here; for more information on the line integral approach, see Yoshioka et al., 2020.
[1] Yoshioka, Keita, Francesco Parisio, Dmitri Naumov, Renchao Lu, Olaf Kolditz, and Thomas Nagel. Comparative verification of discrete and smeared numerical approaches for the simulation of hydraulic fracturing. GEM-International Journal on Geomathematics 10, no. 1 (2019): 1-35.
[2] Yoshioka, Keita, Dmitri Naumov, and Olaf Kolditz. On crack opening computation in variational phase-field models for fracture. Computer Methods in Applied Mechanics and Engineering 369 (2020): 113210.
Generated with Hugo 0.147.9 in CI job 578988 | Last revision: December 6, 2022
