Consider a plate, $\Omega=[0,2]\times [-0.5,0.5]$, with an explicit edge crack, $\Gamma=[0,0.5]\times \{0\}$; that is subjected to a time dependent crack opening displacement:
\begin{eqnarray} \label{eq:surfing_bc} \mathbf{u}(x,y,t)= \mathbf{U}(x-\text{v}t,y) \quad \text{on} \quad \partial\Omega_D, \end{eqnarray} where $\text{v}$ is an imposed loading velocity; and $\mathbf{U}$ is the asymptotic solution for the Mode-I crack opening displacement \begin{eqnarray} \label{eq:asymptotic} U_x= \dfrac{K_I}{2\mu} \sqrt{\dfrac{r}{2\pi}} (\kappa-\cos \varphi) \cos \frac{\varphi}{2}, \nonumber \ U_y= \dfrac{K_I}{2\mu} \sqrt{\dfrac{r}{2\pi}} (\kappa-\cos \varphi) \sin \frac{\varphi}{2}, \end{eqnarray}
where $K_I$ is the stress intensity factor, $\kappa=(3-\nu)/(1+\nu)$ and $\mu=E / 2 (1 + \nu) $; $(r,\varphi)$ are the polar coordinate system, where the origin is crack tip. Also, we used $G_\mathrm{c}=K_{Ic}^2(1-\nu^2)/E$ as the fracture surface energy under plane strain condition. Table 1 lists the material properties and geometry of the numerical model.
Name | Value | Unit | Symbol |
Young’s modulus | 210x$10^3$ | MPa | $E$ |
Critical energy release rate | 2.7 | MPa$\cdot$mm | $G_{c}$ |
Poisson’s ratio | 0.3 | $-$ | $\nu$ |
Regularization parameter | 2$h$ | mm | $\ell_s$ |
Imposed loading velocity | 1.5 | mm/s | $\text{v}$ |
Length | $2$ | mm | $L$ |
Height | $1$ | mm | $H$ |
Initial crack length | $0.5$ | mm | $a_0$ |
(click to toggle)
import time
from scipy.spatial import Delaunay
x_tip_Initial = 0.5
(click to toggle)
x_tip_Initial = 0.5
y_tip_Initial = 0.5
Height = 1.0
Orientation = 0
h = 0.05
G_i = 2.7
ls = 2 * h
# We set ls=2h in our simulation
phasefield_model = "AT1" # AT1 and AT2
# file's name
(click to toggle)
# file's name
prj_name = "surfing.prj"
# https://www.opengeosys.org/docs/tools/meshing/structured-mesh-generation/
(click to toggle)
run(
f"generateStructuredMesh -o {out_dir}/surfing_quad_1x2.vtu -e quad --lx 2 --nx {round(2/h)+1} --ly 1 --ny {round(1/h)+1}",
shell=True,
check=True,
run(
f"NodeReordering -i {out_dir}/surfing_quad_1x2.vtu -o {out_dir}/surfing_quad_1x2_NR.vtu",
shell=True,
check=True,
[0] info: Mesh created: 924 nodes, 861 elements.
[0] info: Reordering nodes...
[0] info: VTU file written.
CompletedProcess(args='NodeReordering -i /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/PhaseField/surfing_jupyter_notebook/surfing_pyvista/surfing_quad_1x2.vtu -o /var/lib/gitlab-runner/builds/vZ6vnZiU/0/ogs/build/release-petsc/Tests/Data/PhaseField/surfing_jupyter_notebook/surfing_pyvista/surfing_quad_1x2_NR.vtu', returncode=0)
At fracture, we set the initial phase field to zero.
pv.set_plot_theme("document")
(click to toggle)
mesh = pv.read(f"{out_dir}/surfing_quad_1x2_NR.vtu")
if (
x[0] < x_tip_Initial + h / 10
and x[1] < Height / 2 + h
and x[1] > Height / 2 - h
phase_field[node_id] = 0.0
mesh.point_data["pf-ic"] = phase_field
mesh.save(f"{out_dir}/surfing_quad_1x2_NR_pf_ic.vtu")
pf_ic = mesh.point_data["pf-ic"]
sargs = {
"title": "pf-ic",
"title_font_size": 20,
"label_font_size": 15,
"n_labels": 5,
"position_x": 0.24,
"position_y": 0.0,
"fmt": "%.1f",
"width": 0.5,
clim = [0, 1.0]
p.add_mesh(
mesh,
scalars=pf_ic,
show_edges=True,
show_scalar_bar=True,
colormap="coolwarm",
clim=clim,
scalar_bar_args=sargs,
p.view_xy()
p.camera.zoom(1.5)
p.window_size = [800, 400]
p.show()
[0m[33m2025-10-14 09:14:42.778 ( 3.445s) [ 7F5010105740]vtkXOpenGLRenderWindow.:1416 WARN| bad X server connection. DISPLAY=[0m
# Change the length scale and phasefield model in project file
(click to toggle)
input_file=prj_name,
MKL=True,
args=f"-o {out_dir}",
gml_file = Path("./surfing.gml").resolve()
model.replace_parameter_value(name="ls", value=2 * h)
model.replace_text(Path("./Surfing_python.py").resolve(), xpath="./python_script")
t0 = time.time()
run(
shell=True,
check=True,
tf = time.time()
print(">>> OGS terminated execution <<< Elapsed time: ", round(tf - t0, 2), " s.")
>>> OGS terminated execution <<< Elapsed time: 17.13 s.
We computed the energy release rate using $G_{\theta}$ method (Destuynder et al., 1983; Li et al., 2016) and plot the errors against the theoretical numerical toughness i.e. $(G_c^{\text{eff}})_{\texttt{num}}=G_c(1+\frac{h}{2\ell})$ for $\texttt{AT}_2$, and $(G_c^{\text{eff}})_{\texttt{num}}=G_c(1+\frac{3h}{8\ell})$ for $\texttt{AT}_1$ (Bourdin et al., 2008).
R_inn = 4 * ls
(click to toggle)
R_inn = 4 * ls
R_out = 2.5 * R_inn
if phasefield_model == "AT1":
G_eff = G_i * (1 + 3 * h / (8 * ls))
G_eff = G_i * (1 + h / (2 * ls))
We run the simulation with a coarse mesh here to reduce computing time; however, a finer mesh would give a more accurate results. The energy release rate and its error for Models $\texttt{AT}_1$ and $\texttt{AT}_2$ with a mesh size of $h=0.005$ are shown below.
reader = pv.get_reader(f"{out_dir}/surfing.pvd")
(click to toggle)
G_theta_time = np.zeros((len(reader.time_values), 2))
for t, time_value in enumerate(reader.time_values):
mesh = reader.read()[0]
xs = mesh.points[:, 0]
ys = mesh.points[:, 1]
num_points = disp.shape
theta = np.zeros(num_points)
# find fracture tip
min_pf = min(pf[:])
coord_pf_0p5 = mesh.points[pf < 0.5]
if min_pf <= 0.5:
coord_pf_0p5[np.argmax(coord_pf_0p5, axis=0)[0]][1]
x0 = coord_pf_0p5[np.argmax(coord_pf_0p5, axis=0)[0]][0]
y0 = coord_pf_0p5[np.argmax(coord_pf_0p5, axis=0)[0]][1]
x0 = x_tip_Initial
y0 = y_tip_Initial
Crack_position = [x0, y0]
# define \theta
for i, x in enumerate(mesh.points):
# distance from the crack tip
R = np.sqrt((x[0] - Crack_position[0]) ** 2 + (x[1] - Crack_position[1]) ** 2)
if R_inn > R:
theta_funct = 1.0
elif R_out < R:
theta_funct = 0.0
theta_funct = (R - R_out) / (R_inn - R_out)
theta[i][0] = theta_funct * np.cos(Orientation)
theta[i][1] = theta_funct * np.sin(Orientation)
mesh.point_data["theta"] = theta
# define grad \theta
mesh_theta = mesh.compute_derivative(scalars="theta")
mesh_theta["gradient"]
keys = np.array(
["thetax_x", "thetax_y", "thetax_z", "thetay_x", "thetay_y", "thetay_z"]
keys = keys.reshape((2, 3))[:, : mesh_theta["gradient"].shape[1]].ravel()
gradients_theta = dict(zip(keys, mesh_theta["gradient"].T, strict=True))
mesh.point_data.update(gradients_theta)
# define grad u
mesh_u = mesh.compute_derivative(scalars="displacement")
mesh_u["gradient"]
keys = np.array(["Ux_x", "Ux_y", "Ux_z", "Uy_x", "Uy_y", "Uy_z"])
keys = keys.reshape((2, 3))[:, : mesh_u["gradient"].shape[1]].ravel()
gradients_u = dict(zip(keys, mesh_u["gradient"].T, strict=True))
mesh.point_data.update(gradients_u)
# define G_theta
G_theta_i = np.zeros(num_points[0])
Ux_x = mesh.point_data["Ux_x"]
Ux_y = mesh.point_data["Ux_y"]
Uy_x = mesh.point_data["Uy_x"]
Uy_y = mesh.point_data["Uy_y"]
thetax_x = mesh.point_data["thetax_x"]
thetax_y = mesh.point_data["thetax_y"]
thetay_x = mesh.point_data["thetay_x"]
thetay_y = mesh.point_data["thetay_y"]
sigma_xx = sigma[i][0]
sigma_yy = sigma[i][1]
sigma_xy = sigma[i][3]
Ux_x_i = Ux_x[i]
Ux_y_i = Ux_y[i]
Uy_x_i = Uy_x[i]
Uy_y_i = Uy_y[i]
thetax_x_i = thetax_x[i]
thetax_y_i = thetax_y[i]
thetay_x_i = thetay_x[i]
thetay_y_i = thetay_y[i]
dUdTheta_11 = Ux_x_i * thetax_x_i + Ux_y_i * thetay_x_i
dUdTheta_12 = Ux_x_i * thetax_y_i + Ux_y_i * thetay_y_i
dUdTheta_21 = Uy_x_i * thetax_x_i + Uy_y_i * thetay_x_i
dUdTheta_22 = Uy_x_i * thetax_y_i + Uy_y_i * thetay_y_i
trace_sigma_grad_u_grad_theta = (
sigma_xx * dUdTheta_11
+ sigma_xy * (dUdTheta_12 + dUdTheta_21)
+ sigma_yy * dUdTheta_22
trace_sigma_grad_u = (
sigma_xx * Ux_x_i + sigma_xy * (Uy_x_i + Ux_y_i) + sigma_yy * Uy_y_i
div_theta_i = thetax_x_i + thetay_y_i
G_theta_i[i] = (
trace_sigma_grad_u_grad_theta - 0.5 * trace_sigma_grad_u * div_theta_i
mesh.point_data["G_theta_node"] = G_theta_i
# Integral G_theta
X = mesh.points[:, 0]
Y = mesh.points[:, 1]
G_theta_i = mesh.point_data["G_theta_node"]
domain_points = np.array(list(zip(X, Y, strict=True)))
tri = Delaunay(domain_points)
def area_from_3_points(x, y, z):
return np.sqrt(np.sum(np.cross(x - y, x - z), axis=-1) ** 2) / 2
G_theta = 0
for vertices in tri.simplices:
mean_value = (
G_theta_i[vertices[0]] + G_theta_i[vertices[1]] + G_theta_i[vertices[2]]
) / 3
area = area_from_3_points(
domain_points[vertices[0]],
domain_points[vertices[1]],
domain_points[vertices[2]],
G_theta += mean_value * area
G_theta_time[t][1] = G_theta
G_theta_time[t][0] = time_value
mesh.save(f"{out_dir}/surfing_Post_Processing.vtu")
/tmp/ipykernel_1210781/1910372099.py:131: DeprecationWarning: Arrays of 2-dimensional vectors are deprecated. Use arrays of 3-dimensional vectors instead. (deprecated in NumPy 2.0)
plt.xlabel("$t$", fontsize=14)
(click to toggle)
plt.ylabel(
r"$\frac{|{G}_\mathrm{\theta}-({G}_\mathrm{c}^{\mathrm{eff}})_\mathrm{num}|}{({G}_\mathrm{c}^{\mathrm{eff}})_\mathrm{num}}\times 100\%$",
fontsize=14,
plt.plot(
G_theta_time[:, 0],
abs(G_theta_time[:, 1]) / G_eff,
"-ob",
fillstyle="none",
linewidth=1.5,
label=f"Phase-field {phasefield_model}",
plt.plot(
G_theta_time[:, 0],
np.append(0, np.ones(len(G_theta_time[:, 0]) - 1)),
"-k",
fillstyle="none",
linewidth=1.5,
label="Closed form",
plt.grid(linestyle="dashed")
plt.xlim(-0.05, 0.8)
plt.ylabel(
fontsize=14,
plt.plot(
G_theta_time[:, 0],
abs(G_theta_time[:, 1] - G_eff) / G_eff * 100,
"-ob",
fillstyle="none",
linewidth=1.5,
# plt.ylim(0,4)
Hint: Accurate results can be obtained by using the mesh size below 0.02.
plotter = pv.Plotter()
(click to toggle)
plotter.open_gif("figures/surfing.gif")
mesh = reader.read()[0] # This dataset only has 1 block
sargs = {
"title": "Phase field",
"n_labels": 5,
"position_x": 0.3,
"position_y": 0.2,
"fmt": "%.1f",
"width": 0.5,
clim = [0, 1.0]
plotter.clear()
plotter.add_mesh(
mesh,
scalars=pf,
show_scalar_bar=False,
clim=clim,
lighting=False,
plotter.view_xy()
plotter.write_frame()
plotter.close()
(click to toggle)
p.add_mesh(
mesh,
scalars=pf,
show_edges=False,
clim=clim,
p.view_xy()
p.camera.zoom(1.5)
p.show()
[1] B. Bourdin, G.A. Francfort, and J.-J. Marigo, The variational approach to fracture, Journal of Elasticity 91 (2008), no. 1-3, 5–148.
[2] Li, Tianyi, Jean-Jacques Marigo, Daniel Guilbaud, and Serguei Potapov. Numerical investigation of dynamic brittle fracture via gradient damage models. Advanced Modeling and Simulation in Engineering Sciences 3, no. 1 (2016): 1-24.
[3] Dubois, Frédéric and Chazal, Claude and Petit, Christophe, A Finite Element Analysis of Creep-Crack Growth in Viscoelastic Media, Mechanics Time-Dependent Materials 2 (1998), no. 3, 269–286
in CI job 629815
Last revision: June 28, 2022
