In this benchmark example we consider a linear elastic small deformation problem. More specifically, a plate with a central hole that is put under tension on its top boundary is simulated. By exploiting symmetries, below we evaluate this problem just for the top right quarter of this disc.
Doing this it is important to define boundary conditions for the regarded section of the plate. For the bottom boundary ($x$-axis, $\theta=-90°$) and the left boundary ($y$-axis, $\theta=0°$) we prescribe Dirichlet boundary conditions that constrain the normal displacement along the edge to be zero. On the top, where a tensile traction is applied to the plate, Neumann boundary conditions are prescribed.
For the description of the plate and its load, some dimensions need to be defined. The quarter disc under consideration can be seen as a square with an edge length of $10\, \text{cm}$. The radius of the circular hole is $a = 2\, \text{cm}$ and the applied tension on the top boundary has a value of $\sigma = 10\, \text{kPa}$.
To fully capture and understand the behaviour of stress and strain distributions around the hole, it is necessary to also define material properties. In case of isotropic linear elasticity, the relevant parameters are the Young’s modulus and Poisson’s ratio. The following parameters are chosen here:
$ E = 1\,\text{MPa} \qquad \nu = 0.3$
For verification of the numerical implementation, the numerical solution of the problem will be compared to the analytical solution.
The overall stress distributions in the plate around the hole can be represented by Kirsch’s Solution, which is expressed here in cylindrical coordinates. The following equations are valid for an infinitely extended plate. Since the hole is very small compared to the dimension of the plate, we can consider this condition as fulfilled. The parameter $\sigma$ is the applied tension and $a$ is the radius of the inner hole. $r$ and $\theta$ are the cylindrical coordinates of a point in the plate. $r$ is measured from the origin (i.e., center of the hole), and $\theta$ is measured clockwise from the positive $y$-axis, i.e. the $x$-axis is at $\theta = -90°$.
$$ \begin{align} \sigma_{rr} \left( r , \theta \right) &= \frac{\sigma}{2} \left[ \left( 1 - \frac{a^2}{r^2} \right) + \left( 1 + 3 \frac{a^4}{r^4} - 4 \frac{a^2}{r^2} \right) \cos \left( 2 \theta \right) \right] \\ \sigma_{\theta \theta} \left( r , \theta \right) &= \frac{\sigma}{2} \left[ \left( 1 + \frac{a^2}{r^2} \right) - \left( 1 + 3 \frac{a^4}{r^4} \right) \cos \left( 2 \theta \right) \right] \\ \sigma_{r \theta} \left( r , \theta \right) &= - \frac{\sigma}{2} \left[ \left( 1 - 3 \frac{a^4}{r^4} + 2 \frac{a^2}{r^2} \right) \sin \left( 2 \theta \right) \right] \end{align} $$For visualization of the stress distribution within the plate the stresses $\sigma_{rr}$, $\sigma_{\theta\theta}$ and $\sigma_{r\theta}$ are plotted along the $x$- and $y$-axes as well as along the diagonal ($\theta = -45°$). As can be seen below, the hole causes characteristic stress distributions.
(click to toggle)
# Some plot settings
(click to toggle)
(click to toggle)
# Änderung in Heaviside-Funktion: Spannung erst ab r=1.99... auf Null setzen, da erster Eintrag von dist_sorted etwas kleiner als 2 ist
return (
0.5
* sig
(1 - a**2 / r**2)
return (
0.5
* sig
(1 + a**2 / r**2)
return (
-0.5
* sig
At larger distances from the hole the stresses are approximately distributed as if the plate had no hole ($\sigma_{rr} \equiv \sigma_{xx} \approx 0$, $\sigma_{r\theta} \equiv \sigma_{xy} = 0$, $\sigma_{\theta\theta} \equiv \sigma_{yy} = 10\,\text{kPa}$). As the hole is approached, the tangential stress increases until it reaches its maximum value directly at the contour. Interestingly, that value is three times as high as the applied traction. It can be concluded that the hole leads to a threefold stress concentration.
r = np.linspace(2, 10, 1000)
(click to toggle)
plt.plot(r, kirsch_sig_rr(10, r, -90, 2), label=r"$\sigma_{rr} \equiv \sigma_{xx}$")
plt.plot(
r,
kirsch_sig_tt(10, r, -90, 2),
label=r"$\sigma_{\theta \theta} \equiv \sigma_{yy}$",
plt.plot(
r, kirsch_sig_rt(10, r, -90, 2), label=r"$\sigma_{r \theta} \equiv \sigma_{xy}$"
plt.plot([2, 2], [0, 30], color="0.6", linestyle="--", label="Hole Radius")
plt.legend(loc="upper right")
plt.tight_layout()
plt.grid(True)
plt.xlabel(r"$r\equiv x$ / cm")
plt.xlim(0, 10)
plt.ylabel(r"$\sigma$ / kPa")
plt.ylim(0, 30)
(0.0, 30.0)
r = np.linspace(2, 14.14, 1000)
(click to toggle)
plt.plot(r, kirsch_sig_rr(10, r, -45, 2), label=r"$\sigma_{rr}$")
plt.plot(r, kirsch_sig_tt(10, r, -45, 2), label=r"$\sigma_{\theta \theta}$")
plt.plot(r, kirsch_sig_rt(10, r, -45, 2), label=r"$\sigma_{r \theta}$")
plt.axvline(2, color="0.6", linestyle="--", label="Hole Radius")
plt.tight_layout()
plt.grid(True)
plt.xlabel(r"$r$ / cm")
plt.xlim(0, 14.14)
plt.ylim(0, 10)
(0.0, 10.0)
Attention: Radius is plotted along the vertical axis. I.e., upwards direction in the plot corresponds to the upwards ($y$) direction of the problem.
The horizontal stress near the hole amounts to the negative of the applied tension. Far away from the hole ($r\to\infty$) it vanishes.
The vertical stress is zero at the edge of the hole and exhibits a sign change in the vicinity of the hole.
(click to toggle)
plt.plot(kirsch_sig_rr(10, r, 0, 2), r, label=r"$\sigma_{rr} \equiv \sigma_{yy}$")
plt.plot(
kirsch_sig_tt(10, r, 0, 2), r, label=r"$\sigma_{\theta \theta} \equiv \sigma_{xx}$"
plt.plot(kirsch_sig_rt(10, r, 0, 2), r, label=r"$\sigma_{r \theta} \equiv \sigma_{xy}$")
plt.axhline(2, color="0.6", linestyle="--", label="Hole Radius")
plt.legend()
plt.tight_layout()
plt.grid(True)
ax = plt.gca()
plt.ylabel(r"$r\equiv y$ / cm")
plt.xlabel(r"$\sigma$ / kPa")
plt.xlim(-10, 10)
(-10.0, 10.0)
For gaining a deeper insight for the planar stress distribution in the plate around the hole the following 2D plots are helpful. The magnitude of the acting stresses is expressed by a chromatic graduated scale in separate plots for $\sigma_{rr}$, $\sigma_{\theta\theta}$ and $\sigma_{r\theta}$.
def cart_to_cyl(x, y):
return [np.sqrt(x**2 + y**2), np.rad2deg(np.arctan(x / y))]
X, Y = np.meshgrid(np.linspace(0.1, 10, 1000), np.linspace(0.1, 10, 1000))
# cylindical coordinates from Cartesian grid
(click to toggle)
r, theta = cart_to_cyl(X, Y)
eps = 1e-2
fig, ax = plt.subplots(ncols=3, figsize=(18, 6))
l1 = ax[0].contourf(
X, Y, np.ma.masked_array(kirsch_sig_rr(10, r, -theta, 2), mask=r < 2)
l2 = ax[1].contourf(
X, Y, np.ma.masked_array(kirsch_sig_tt(10, r, -theta, 2), mask=r < 2)
l3 = ax[2].contourf(
X, Y, np.ma.masked_array(kirsch_sig_rt(10, r, -theta, 2), mask=r < 2)
fig.colorbar(l1, ax=ax[0])
fig.colorbar(l2, ax=ax[1])
fig.colorbar(l3, ax=ax[2])
for i in range(3):
ax[i].set_aspect("equal")
ax[i].set_xlabel("$x$ / cm")
ax[i].set_ylabel("$y$ / cm")
ax[0].set_title(r"$\sigma_{rr}$ / kPa")
ax[1].set_title(r"$\sigma_{\theta\theta}$ / kPa")
ax[2].set_title(r"$\sigma_{r\theta}$ / kPa")
In the following section the previously analytically considered problem of the plate with a central hole is solved with numerical methods (FEM in OpenGeoSys). OpenGeoSys performs computations in Cartesian coordinates. In order to control, display and compare the results of the numerical solution with the analytical it is necessary to convert the output values from Cartesian coordinates to polar coordinates. The formulae below are used to obtain the coordinates $r$ and $\theta$ of the polar coordinate system.
$$ \begin{align} r &= \sqrt{\left(x^2+y^2\right)} \\ \theta &= \arctan\left(\frac yx \right) \\ \end{align} $$For the simulation of the numerical model, some assumptions have to be made:
Simultaneous to the analytical solution the results of the numerical model are plotted along the $x$-, $y$- and diagonal axis. To visualize local differences to the analytically computed stress distribution of $\sigma_{rr}$, $\sigma_{\theta\theta}$ and $\sigma_{r\theta}$ the latter are also added in the plots as dotted lines.
For a better presentation of these differences and as a basis for the following error analysis, plots for absolute and relative error along the regarded axes are have been made.
(click to toggle)
if not out_dir.exists():
out_dir.mkdir(parents=True)
model = ot.Project(input_file="disc_with_hole.prj", output_file="disc_with_hole.prj")
OGS finished with project file disc_with_hole.prj.
Execution took 0.2484581470489502 s
pv.set_plot_theme("document")
pv.set_jupyter_backend("static") # comment out for interactive graphics
reader = pv.get_reader(f"{out_dir}/disc_with_hole.pvd")
(click to toggle)
reader.set_active_time_value(1.0) # go to 1 s
mesh = reader.read()[0] # nulltes Gitter lesen
def vec4_to_mat3x3cart(vec4):
(click to toggle)
# theta = np.arctan2(ys, xs)
m = np.zeros((3, 3))
m[0, 0] = vec4[0]
m[1, 1] = vec4[1]
m[2, 2] = vec4[2]
m[0, 1] = vec4[3]
m[1, 0] = vec4[3]
return np.matrix(m)
def vec4_to_mat3x3polar(
vec4, xs, ys
): # Fkt wandelt Kelvin Darstellung (von ogs ausgegeben) in Tensor um
rot = np.matrix(np.eye(3)) # 3x3 Einheitsmatrix
rot[0, 0] = np.cos(theta)
rot[0, 1] = -np.sin(theta)
rot[1, 0] = np.sin(theta)
rot[1, 1] = np.cos(theta) # rot = Drehmatrix, Drehung um z-Achse
return rot.T * m_cart * rot
pt1 = (0, 1e-6, 0)
(click to toggle)
pt1 = (0, 1e-6, 0)
pt2 = (10, 1e-6, 0)
xaxis = pv.Line(pt1, pt2, resolution=2)
line_mesh = mesh.slice_along_line(xaxis)
xs = line_mesh.points[:, 0] # x (0) coordinate of each point (Spalte 0)
ys = line_mesh.points[:, 1] # y Koordinate jedes Punktes (Spalte 1)
dist_from_origin = np.hypot(xs, ys) # Abstand vom Ursprung (= Radius)
indices_sorted = np.argsort(
dist_from_origin
) # Indizes der Punkte sortieren nach ihrem Abstand vom Ursprung
dist_sorted = dist_from_origin[indices_sorted] # index magic
sig = line_mesh.point_data["sigma"]
(click to toggle)
num_points = sig.shape[0] # entspricht len(sig) d.h Anzahl der Punkte, hier 36
(click to toggle)
sig_rr = np.zeros(num_points) # Liste von 36 Nullen
sig_tt = np.zeros(num_points)
sig_rt = np.zeros(num_points)
(click to toggle)
sig_vec = sig[pt_idx, :]
xs = line_mesh.points[pt_idx, 0]
ys = line_mesh.points[pt_idx, 1]
sig_polar = vec4_to_mat3x3polar(sig_vec, xs, ys)
sig_rr[pt_idx] = sig_polar[0, 0]
sig_tt[pt_idx] = sig_polar[1, 1]
sig_rt[pt_idx] = sig_polar[0, 1]
(click to toggle)
(click to toggle)
f_abs_rr[pt_idx] = sig_rr_sorted[pt_idx] * 1000 - kirsch_sig_rr(
10, dist_sorted[pt_idx], -90, 2
f_abs_tt[pt_idx] = sig_tt_sorted[pt_idx] * 1000 - kirsch_sig_tt(
f_abs_rt[pt_idx] = sig_rt_sorted[pt_idx] * 1000 - kirsch_sig_rt(
if kirsch_sig_rr(10, dist_sorted[pt_idx], -90, 2) == 0:
f_rel_rr[pt_idx] = f_abs_rr[pt_idx] / kirsch_sig_rr(
if kirsch_sig_tt(10, dist_sorted[pt_idx], -90, 2) == 0:
f_rel_tt[pt_idx] = f_abs_tt[pt_idx] / kirsch_sig_tt(
if kirsch_sig_rt(10, dist_sorted[pt_idx], -90, 2) == 0:
f_rel_rt[pt_idx] = f_abs_rt[pt_idx] / kirsch_sig_rt(
(click to toggle)
for i in range(3):
ax[i].axvline(2, color="0.6", linestyle="--", label="Hole Radius")
ax[i].grid(True)
ax[i].set(xlim=(0, 10))
ax[i].set_xlabel("$r$ / cm")
ax[0].plot(
r,
color="deepskyblue",
linestyle=":",
label=r"$\sigma_{rr,\mathrm{analytical}}$",
ax[0].plot(
r,
color="yellowgreen",
linestyle=":",
label=r"$\sigma_{\theta\theta,\mathrm{analytical}}$",
ax[0].plot(
r,
color="orangered",
linestyle=":",
label=r"$\sigma_{r\theta,\mathrm{analytical}}$",
ax[0].plot(dist_sorted, sig_rr_sorted * 1000, label=r"$\sigma_{rr}$")
ax[0].plot(dist_sorted, sig_tt_sorted * 1000, label=r"$\sigma_{\theta\theta}$")
ax[0].plot(dist_sorted, sig_rt_sorted * 1000, label=r"$\sigma_{r\theta}$")
ax[0].set_ylabel(r"$\sigma$ / kPa")
ax[0].set(ylim=(-2, 35.5))
ax[0].legend(loc="upper right")
ax[1].plot(dist_sorted, f_abs_rr, label=r"$\Delta\sigma_{rr}$")
ax[1].plot(dist_sorted, f_abs_tt, label=r"$\Delta\sigma_{\theta\theta}$")
ax[1].plot(dist_sorted, f_abs_rt, label=r"$\Delta\sigma_{r\theta}$")
# ax[1].spines['bottom'].set_position('zero')
ax[1].spines["top"].set_color("none")
ax[1].xaxis.tick_bottom()
ax[1].set_ylabel(r"$\Delta\sigma$ / kPa")
ax[1].set(ylim=(-2, 4.5))
ax[2].plot(
dist_sorted,
f_rel_rr,
label=r"$\Delta\sigma_{rr}$ / $\sigma_{rr,\mathrm{analytical}}$",
ax[2].plot(
dist_sorted,
f_rel_tt,
label=r"$\Delta\sigma_{\theta\theta}$ / $\sigma_{\theta\theta,\mathrm{analytical}}$",
# ax[2].plot(dist_sorted, f_rel_rt, label = r"$\Delta\sigma_{r\theta}$ / $\sigma_{r\theta,analytical}$")
ax[2].set_ylim(-0.2, 0.2)
ax[2].set_ylabel(r"$\Delta\sigma$ / $\sigma_{\mathrm{analytical}}$")
ax[2].legend() # loc="upper right")
ax[0].set_title("Stress distribution")
ax[1].set_title("Absolute error")
ax[2].set_title("Relative error")
pt1 = (0, 0, 0)
(click to toggle)
pt1 = (0, 0, 0)
pt2 = (10, 10, 0)
diagonal = pv.Line(
) # erstellt Linie zwischen den Punkten und teilt sie in 2 Teile (resolution)
diagonal
) # Schnitt durch das Gitter entlang der Linie (ergibt 1D Gitter mit 35 Zellen und 36 Punkten)
dist_from_origin = np.hypot(xs, ys) # Abstand vom Ursprung (Radius)
dist_from_origin
(click to toggle)
"sigma"
] # Spannung in Kelvin Darstellung als 4 zeiliger Vector statt 3x3 Matrix
# Achtung (CL): Das ist nicht ganz die Kelvin-Darstellung. Die Kelvin-Darstellung hat noch Faktoren sqrt(2) bei den Nichtdiagonalelementen.
(click to toggle)
(click to toggle)
(click to toggle)
(click to toggle)
10, dist_sorted[pt_idx], -45, 2
if kirsch_sig_rr(10, dist_sorted[pt_idx], -45, 2) == 0:
if kirsch_sig_tt(10, dist_sorted[pt_idx], -45, 2) == 0:
if kirsch_sig_rt(10, dist_sorted[pt_idx], -45, 2) == 0:
(click to toggle)
for i in range(3):
ax[i].grid(True)
ax[i].set(xlim=(0, 14.14))
ax[0].plot(
r,
linestyle=":",
ax[0].plot(
r,
linestyle=":",
ax[0].plot(
r,
color="orangered",
linestyle=":",
ax[0].set(ylim=(0, 12))
ax[1].set(ylim=(-0.5, 1.3))
ax[2].plot(
dist_sorted,
f_rel_rr,
ax[2].plot(
dist_sorted,
f_rel_tt,
ax[2].plot(
dist_sorted,
f_rel_rt,
label=r"$\Delta\sigma_{r\theta}$ / $\sigma_{r\theta,\mathrm{analytical}}$",
ax[2].set(ylim=(-0.1, 0.3))
ax[2].legend(loc="upper right")
pt1 = (0, 0, 0)
(click to toggle)
pt1 = (0, 0, 0)
pt2 = (0, 10, 0)
yaxis = pv.Line(pt1, pt2, resolution=2)
line_mesh = mesh.slice_along_line(yaxis)
(click to toggle)
(click to toggle)
(click to toggle)
(click to toggle)
(click to toggle)
10, dist_sorted[pt_idx], 0, 2
if kirsch_sig_rr(10, dist_sorted[pt_idx], 0, 2) == 0:
f_rel_rr[pt_idx] = f_abs_rr[pt_idx] / 1e-6
if kirsch_sig_tt(10, dist_sorted[pt_idx], 0, 2) == 0:
f_rel_tt[pt_idx] = f_abs_tt[pt_idx] / 1e-6
if kirsch_sig_rt(10, dist_sorted[pt_idx], 0, 2) == 0:
f_rel_rt[pt_idx] = f_abs_rt[pt_idx] / 1e-6
(click to toggle)
for i in range(3):
ax[i].grid(True)
ax[0].plot(
r,
linestyle=":",
ax[0].plot(
r,
linestyle=":",
ax[0].plot(
r,
color="orangered",
linestyle=":",
ax[0].set(ylim=(-14, 10.5))
ax[0].legend(loc="lower right")
ax[0].spines["right"].set_color("none")
ax[0].spines["top"].set_color("none")
ax[0].xaxis.set_ticks_position("bottom")
ax[0].yaxis.set_ticks_position("left")
ax[0].spines["left"].set_position(("data", 0))
ax[1].set(ylim=(-3.5, 2.5))
ax[1].legend(loc="lower right")
ax[2].plot(
dist_sorted,
f_rel_rr,
ax[2].plot(
dist_sorted,
f_rel_tt,
ax[2].set(ylim=(-1, 1))
ax[2].legend(loc="lower right")
In this following section, the differences of the numerical to the analytical solution are discussed. Doing this, one studies various aspects of the numerical solution.
Whenever a problem is solved by finite element method (FEM), discretization errors occur. They arise from the creation of the mesh, since the result is calculated only at a finite number of nodes. Discretization errors can be minimized by refining the mesh. However, this increases computing time, so a compromise must be found.
Accordingly, this error smaller or larger and has to be acceptable for the field of application.
The following image illustrates the chosen mesh for this benchmark example. In the area around the cavity, the stress gradients are rather high, as can also be seen in the diagrams above, and thus call for a finer mesh resolution.
plotter = pv.Plotter(window_size=[1024, 500])
(click to toggle)
plotter.show_bounds(ticks="outside", xlabel="x / cm", ylabel="y / cm")
# plotter.add_axes()
plotter.view_xy()
/var/lib/gitlab-runner/builds/geF4QCR1Z/0/ogs/build/release-all/.venv/lib/python3.12/site-packages/pyvista/plotting/renderer.py:1735: PyVistaDeprecationWarning: `xlabel` is deprecated. Use `xtitle` instead.
warnings.warn(
/var/lib/gitlab-runner/builds/geF4QCR1Z/0/ogs/build/release-all/.venv/lib/python3.12/site-packages/pyvista/plotting/renderer.py:1741: PyVistaDeprecationWarning: `ylabel` is deprecated. Use `ytitle` instead.
warnings.warn(
All three stress components of the numerical solution show a more or less pronounced buckle most obviously along the diagonal- and y-axes in the middle of the observed radius range. The reason for this is the fact that the mesh is refined in the area around the hole. This increases the accuracy and resolution, but at the same time, the cells become distorted rectangles instead of squares.
Another source of error is the limitation of the plate’s geometry. In a continuous, infinitely extended plate the stress distribution approaches the primary stress state with distance from the cavity. The example of the stress distribution along the y-axis shows that the numerical solution for $\sigma_{rr}$ reaches the Neumann boundary condition set with a value of $10\, \text{kPa}$ for $\text{r} = 10\, \text{cm}$. With Kirsch’s Solution for the analytical calculation, $\sigma_{rr}$ converges only at infinity towards the value of $10\, \text{kPa}$ and amounts approximately $9\, \text{kPa}$ for $r = 10\, \text{cm}$.
A similar error becomes visible along the $x$-axis. The Neumann boundary condition constrains the normal stress along the right edge to be zero . As a consequence $\sigma_{rr}$ must reach a value of $0\, \text{MPa}$ for $r = 10\, \text{cm}$ to satisfy the boundary condition. In the analytical solution however, $\sigma_{rr}$ approaches zero at infinity and thus is larger than in the numerical solution. Errors of that type can be minimized by increasing the plates dimensions or decreasing the diameter of the cavity, so that the boundary conditions do not interfere with the cavity-disturbed stress distribution.
As a rule of thumb, it can be assumed in this case that the boundaries of the problem can be drawn after at least five-hole radii.
Further artefacts, called extrapolation errors occur at all boundaries of the numerical model. It can be recognised by a discontinuity in the graph for the stress distribution and absolute error next to the cavity ($r = 2\, \text{cm}$) and the plate boundaries ($r = 10\, \text{cm}$ resp. $r = 14.14\, \text{cm}$). The stress is derived from strain and this in turn from the nodal displacement. Therefore, there are no calculated stress magnitudes on the nodes, but they are formed as the average value of the neighboring cells. However, if the node is located on the edge directly next to the cavity or plate boundary, no average value can be formed, but the stress is extrapolated. In contrast to most of the other errors, this one is not based on an defect in the calculation of the numerical model, but rather in the output.
As can see below the 2D color plots of the numerical solution resemble those of the analytical solution. The plot of the tangential stress $\sigma_{\theta\theta}$ also shows a threefold stress concentration. From the plot of the radial stress $\sigma_{rr}$ it becomes clear that the Neumann boundary condition that respects the applied tensile stress of $10 \text{kPa}$ at the top boundary is satisfied.
points = mesh.point_data["sigma"].shape[0]
(click to toggle)
sig_polar = np.zeros([points, 3, 3])
(click to toggle)
sig_rr = np.zeros([points, 1])
sig_tt = np.zeros([points, 1])
sig_rt = np.zeros([points, 1])
xs = mesh.points[:, 0]
(click to toggle)
ys = mesh.points[:, 1]
sig_vec = mesh.point_data["sigma"]
for i in range(xs.shape[0]):
sig_polar[i] = vec4_to_mat3x3polar(sig_vec[i, :], xs[i], ys[i])
sig_rr[i] = sig_polar[i, 0, 0]
sig_tt[i] = sig_polar[i, 1, 1]
sig_rt[i] = sig_polar[i, 0, 1]
mesh2 = mesh.copy(deep=False) # workaround some pyvista bug with multiple plots
(click to toggle)
mesh3 = mesh.copy(deep=False)
sargs = {
"title": "sigma_rr / kPa",
"title_font_size": 25,
"label_font_size": 15,
"n_labels": 4,
"position_x": 0.05,
"position_y": 0.85,
"fmt": "%.1f",
"width": 0.9,
clim = [-10, 10]
p = pv.Plotter(shape=(1, 3), border=False)
p.subplot(0, 0)
p.add_mesh(
mesh,
scalars=sig_rr * 1000,
show_edges=False,
show_scalar_bar=True,
colormap="RdBu_r",
clim=clim,
scalar_bar_args=sargs,
# p.add_axes()
p.view_xy()
p.camera.zoom(2)
sargs1 = {
"title": "sigma_tt / kPa",
"n_labels": 4,
"position_x": 0.05,
"position_y": 0.85,
"fmt": "%.1f",
"width": 0.9,
clim = [-35, 35]
p.subplot(0, 1)
p.add_mesh(
mesh2,
scalars=sig_tt * 1000,
show_edges=False,
colormap="RdBu_r",
clim=clim,
scalar_bar_args=sargs1,
# p.add_axes()
p.view_xy()
p.camera.zoom(2)
sargs2 = {
"title": "sigma_rt / kPa",
"n_labels": 4,
"position_x": 0.05,
"position_y": 0.85,
"fmt": "%.1f",
"width": 0.9,
clim = [-10, 10]
p.subplot(0, 2)
p.add_mesh(
mesh3,
scalars=sig_rt * 1000,
show_edges=False,
colormap="RdBu_r",
clim=clim,
scalar_bar_args=sargs2,
# p.add_axes()
p.view_xy()
p.camera.zoom(2)
p.window_size = [1000, 400]
p.show()
if True:
(click to toggle)
if True:
plotter = pv.Plotter()
sargs = {
"title": "sigma_rr",
"title_font_size": 20,
"label_font_size": 16,
"n_labels": 4,
"position_x": 0.2,
"position_y": 0.9,
"fmt": "%.1f",
plotter.add_mesh(
mesh,
show_edges=True,
show_scalar_bar=False,
# plotter.show_bounds(ticks="outside")
plotter.view_xy()
if False:
(click to toggle)
if False:
sargs = {
"title": "sigma_tt",
"n_labels": 4,
"position_x": 0.2,
"position_y": 0.9,
"fmt": "%.1f",
plotter.add_mesh(
mesh,
show_edges=True,
plotter.view_xy()
if False:
(click to toggle)
if False:
sargs = {
"title": "sigma_rt",
"n_labels": 4,
"position_x": 0.2,
"position_y": 0.9,
"fmt": "%.1f",
plotter.add_mesh(
mesh,
show_edges=True,
plotter.add_axes()
plotter.view_xy()
Generated with Hugo 0.122.0
in CI job 545140
Last revision: April 27, 2022
