A compiler cache speeds up compilation times by caching object files and reusing them on subsequent builds. This even works for complete rebuilds (i.e. deleting the full build-directory). The compiler cache Ccache is automatically used when it is found by CMake.
Install it with your package manager, e.g.:
sudo apt install ccache
Just load the module:
module load /global/apps/modulefiles/ccache/3.3.3
brew install ccache
Download the Windows x86_64 (binary release)
Just extract the archive and put the ccache.exe
into the PATH
You may want to change the cache directory (environment variable CCACHE_DIR
) or increase the cache size (e.g. run ccache -M 10G
once or set the environment variable CCACHE_MAXSIZE
). See the Ccache docs for configuration instructions.
You can check cache hit statistics with ccache -s
To disable caching:
cmake . -DOGS_DISABLE_COMPILER_CACHE=ON
Generated with Hugo 0.122.0
in CI job 545140
