Connect to a frontend node and start pvserver
via singularity:
ssh frontend1.eve.ufz.de -L 11111:frontend1.eve.ufz.de:11111
# OR: ssh frontend2.eve.ufz.de -L 11111:frontend2.eve.ufz.de:11111
# frontend2 has a NVidia K80 vs a P4000 in frontend1
singularity exec --nv -B /data:/data /data/ogs/images/pv-v5.8.0-egl-py2.sif /opt/paraview/bin/pvserver
On your local machine:
localhost
11111
Settings / Render View
set Remote Render Threshold
to a small value (e.g. 1) to ensure remote renderingThe port tunneling with ssh is required as these ports are blocked from the firewall. If port 11111
is already in use by another user just try a different port, e.g. 11112
: pvserver -sp=11112
. Do not forget to tunnel this port with SSH too!
envinf1
envinf1
has a NVidia K20m. Similar instructions as for eve but port tunneling is not necessary:
ssh 141.65.34.100
pvserver
# or with Singularity:
singularity exec --nv /data/shared/container/pv-v5.8.0-egl-py2.sif /opt/paraview/bin/pvserver
envinf2
envinf2
has a NVidia Quadro RTX 5000. Similar instructions as for eve but port tunneling is not necessary:
ssh 141.65.34.90
pvserver
singularity exec --nv /data/shared/container/pv-v5.9.0-egl-py3.sif /opt/paraview/bin/pvserver
Generated with Hugo 0.122.0
in CI job 545140
