In this three-part tutorial we look at the mechanical deformation of a sedimentary basin under an advancing glacier. In detail we show you a possibility how to
As a common programming language we use Python.
NOTE: Due to ongoing development, msh2vtu.py was integrated in the ogs-repository for ogstools. In order to work with the tutorial and apply msh2vtu on mesh_basin.msh, ogstools need to be installed at first.
ogstools can be installed from PyPI using pip. It is recommended to set up a virtual environment beforehand:
python -m venv .venv
source .venv/bin/activate
pip install ogstools[ogs]
More detailed information about the usages and development of ogstools can be found in ogstools Documentation. After installation the tool can be applied as described in the first video-tutorial. To apply msh2vtu on the mesh_basin.msh the command should look like:
msh2vtu --ogs --rdcd mesh_basin.msh
This article was written by Dominik Kern. If you are missing something or you find an error please let us know.
| Edit
this page on
