In this tutorial the user will learn to use some of the tools provided with OpenGeoSys to create simple mesh for a simulation.
pip
, as a container or as ‘CLI with utilities’ binary download)Please note that this tutorial doesn’t cover Python. The user is expected to have basic understanding of it. Alternatively, other tools capable of reading mesh files can be used (for example: ParaView).
A basic understanding of meshes would make following this tutorial easier but is not required.
If parameters can take different values (for example to apply them in different directions) variable part of command will be indicated by $
sign followed by name.
For example directional parameters set -dx -dy -dz
will be indicated by -d$direction $value
This doesn’t apply to code snippets, there the parameters will be written explicitly.
is used to run shell commands from within the Jupyter notebook.
It is not mandatory to read the following articles before starting with the tutorial, but they can provide some expansion and additional explanation to the content presented here.
In this tutorial, some tools that can be used to create a mesh will be presented with a short description and an example. These tools are shipped as executables with OGS:
Afterwards, you can test your understanding with a couple of exercises.
We first set an output directory and import some required libraries. This tutorial uses PyVista for visualization of the meshes.
(click to toggle)
# All generated files will be put there
# Use pyvista for visualization of the generated meshes
(click to toggle)
pv.set_plot_theme("document")
# Define some plotting functions
(click to toggle)
def show_mesh(mesh):
plotter = pv.Plotter()
plotter.add_mesh(mesh, show_edges=True)
plotter.view_xy()
plotter.add_axes()
plotter.show_bounds(mesh, xtitle="x", ytitle="y")
plotter.window_size = [800, 400]
def show_mesh_3D(mesh):
plotter.add_axes()
def show_cell_sizes_x(mesh):
line = mesh.slice_along_line(pv.Line((0,1e-8,0),(7,1e-8,0), resolution=2))
fig, ax = plt.subplots()
cell_lengths_x = np.diff(line.points[:,0])
num_cells_x = len(cell_lengths_x)
cell_idcs_x = np.arange(1, num_cells_x+1)
ax.plot(cell_idcs_x, cell_lengths_x, marker=".", label="cell sizes from mesh")
ax.plot(cell_idcs_x, 1.2**cell_idcs_x * 0.5, label="cell sizes expected, up to a factor")
ax.legend()
ax.set_xtitle("cell id in $x$ direction")
ax.set_ytitle("cell size in $x$ direction")
ax.set_yscale("log")
You can start by checking the version of the generateStructuredMesh tool, it will test whether your OpenGeoSys is correctly installed and available:
! generateStructuredMesh --version
assert _exit_code == 0
generateStructuredMesh version: 6.5.6-142-g86970195b51
This command should deliver the following output:
generateStructuredMesh version: - some version -
You can view basic documentation using this command:
! generateStructuredMesh --help
USAGE:
generateStructuredMesh [-h] [--version] [-l <none|error|warn|info|debug|
all>] [--dx-max <MAX_X>] [--dx0 <INITIAL_X>]
[--dy-max <MAX_Y>] [--dy0 <INITIAL_Y>] [--dz-max
<MAX_Z>] [--dz0 <INITIAL_Z>] [--lx <LENGTH_X>]
[--ly <LENGTH_Y>] [--lz <LENGTH_Z>] [--mx
<MULTIPLIER_X>] [--my <MULTIPLIER_Y>] [--mz
<MULTIPLIER_Z>] [--nx <SUBDIVISIONS_X>] [--ny
<SUBDIVISIONS_Y>] [--nz <SUBDIVISIONS_Z>] [--ox
<ORIGIN_X>] [--oy <ORIGIN_Y>] [--oz <ORIGIN_Z>]
-e <line|tri|quad|hex|prism|tet|pyramid> -o
<OUTPUT_FILE>
-e <line|tri|quad|hex|prism|tet|pyramid>, --element-type <line|tri|quad|
(required) element type to be created
-o <OUTPUT_FILE>, --mesh-output-file <OUTPUT_FILE>
(required) Output (.vtu). The name of the file the mesh will be
written to
--lx <LENGTH_X>
length of a domain in x direction, (min = 0)
--ly <LENGTH_Y>
length of a domain in y direction, (min = 0)
--lz <LENGTH_Z>
length of a domain in z direction, (min = 0)
the number of subdivision in x direction, (min = 0)
--ny <SUBDIVISIONS_Y>
the number of subdivision in y direction, (min = 0)
the number of subdivision in z direction, (min = 0)
--dx0 <INITIAL_X>
initial cell length in x direction, (min = 0)
--dy0 <INITIAL_Y>
initial cell length in y direction, (min = 0)
--dz0 <INITIAL_Z>
initial cell length in z direction, (min = 0)
--dx-max <MAX_X>
maximum cell length in x direction, (min = 0)
--dy-max <MAX_Y>
maximum cell length in y direction, (min = 0)
--dz-max <MAX_Z>
maximum cell length in z direction, (min = 0)
--mx <MULTIPLIER_X>
multiplier in x direction
--my <MULTIPLIER_Y>
multiplier in y direction
--mz <MULTIPLIER_Z>
multiplier in z direction
--ox <ORIGIN_X>
mesh origin (lower left corner) in x direction
--oy <ORIGIN_Y>
mesh origin (lower left corner) in y direction
--oz <ORIGIN_Z>
mesh origin (lower left corner) in z direction
-l <none|error|warn|info|debug|all>, --log-level <none|error|warn|info|
debug|all>
the verbosity of logging messages
--, --ignore_rest
--version
-h, --help
Structured mesh generator.
The documentation is available at
https://docs.opengeosys.org/docs/tools/meshing/structured-mesh-generatio
n.
OpenGeoSys-6 software, version 6.5.6-142-g86970195b51.
Copyright (c) 2012-2025, OpenGeoSys Community
(http://www.opengeosys.org)
In this step a simple rectangular mesh of size 3 by 4 units, with 4 and 5 cells respectively will be created and written to a quad.vtu
file in folder output
Please follow the folder and file names provided in each step, as some files will be reused later.
In order to select the type of the elements, that the mesh is built with you use the flag -e
followed by one of the available mesh element types.
In this section a mesh of quadrilateral elements is created, so the command will be as follows:
generateStructuredMesh -e quad
this however, is not a complete command.
There are more required parameters, next the name of the output file has to be provided.
It is done using the flag -o
followed by a file name.
If the mesh file should be written to a folder, it can be provided as path relative to the place from where the command is run.
For example:
generateStructuredMesh -e quad -o folder1/folder2/mesh_file_name.vtu
There are two more groups of parameters that need to be provided: length of the mesh in each direction and number of cells in each direction.
The length parameters are indicated by --l$direction $length
, where $direction
is the direction indicated by x, y or z and $length
is length of the mesh.
In order to create mesh with length of 3 in x-direction and 4 in y-direction.
The number of cells is provided in the same convention with parameter --n
: --n$direction $length
In order to create 4 cells in x-direction and 5 cells in y-direction.
The complete command can be written as follows:
generateStructuredMesh -e quad -o {out_dir}/quads.vtu --lx 3 --ly 4 --nx 4 --ny 5
The created mesh can be viewed with any software supporting .vtu
-file format and should look as in the following figure.
Let’s create the mesh with the above command and visualize it:
! generateStructuredMesh -e quad -o {out_dir}/quad.vtu --lx 3 --ly 4 --nx 4 --ny 5
(click to toggle)
mesh = pv.read(f"{out_dir}/quad.vtu")
show_mesh(mesh)
[32minfo:[m Mesh created: 30 nodes, 20 elements.
[0m[33m2025-10-23 14:37:27.277 ( 1.308s) [ 7F69EAC94400]vtkXOpenGLRenderWindow.:1416 WARN| bad X server connection. DISPLAY=[0m
In this step a mesh using triangular cells will be created.
The size and number of cells will remain the same as in previous example.
The produced mesh file will be placed in output
folder in triangle.vtu
file.
Compared to the command from previous step, only element type and output file name changes, therefore we can use it:
generateStructuredMesh -e quad -o out/quads.vtu --lx 3 --ly 4 --nx 4 --ny 5
after changing element type quad
to tri
and file name quad.vtu
to triangle.vtu
! generateStructuredMesh -e tri -o {out_dir}/triangle.vtu --lx 3 --ly 4 --nx 4 --ny 5
[32minfo:[m Mesh created: 30 nodes, 40 elements.
Running this command should create following mesh:
mesh = pv.read(f"{out_dir}/triangle.vtu")
show_mesh(mesh)
By adding parameter --o$direction $value
, the reference point of the created mesh can be shifted.
In this example, the mesh from the step Quadrilateral mesh, will be created again but with the reference point shifted from (0,0) to (2,5) (in (x,y) format).
In order to do this, the final command from that step will be expanded by --ox 2 --oy 5
! generateStructuredMesh -e quad -o {out_dir}/quads.vtu --lx 3 --ly 4 --nx 4 --ny 5 --ox 2 --oy 5
mesh = pv.read(f"{out_dir}/quads.vtu")
show_mesh(mesh)
Compare the values on X and Y axis with the ones in the figure in step Quadrilateral mesh.
In this step a quadrilateral mesh with size of 7 in x-direction and 4 in y-direction (10 and 5 cells respectively) will be created.
However, this time an additional parameter will be passed.
It will change the sizes of the cells from equal to increasingly progressing.
By adding --mx 1.2
, each next cell (in positive direction alongside x-axis) will be 1.2 times bigger than the previous one.
Value below zero will make cells smaller than the previous ones.
The command to create this mesh:
! generateStructuredMesh -e quad -o {out_dir}/quads_graded.vtu --lx 7 --ly 4 --nx 10 --ny 5 \
(click to toggle)
--mx 1.2
[32minfo:[m Mesh created: 66 nodes, 50 elements.
Note that the name of the output file, values in --l
and --n
were changed compared to the command in Quadrilateral mesh step.
The \
allows to break the line and split command into more than one line to improve its readability.
Running it produces following mesh:
mesh = pv.read(f"{out_dir}/quads_graded.vtu")
show_mesh(mesh)
The command from previous step can be expanded with parameter --d$direction0 $value
to define initial cell size, alongside $direction
(x, y, or z).
Let’s say that the initial cell size is 1.
For this case following parameter should be appended: --dx0 1
Expanded command from previous step:
! generateStructuredMesh -e quad -o {out_dir}/quads_graded_init_size.vtu --lx 7 --ly 4 --ny 5 \
(click to toggle)
--mx 1.2 --dx0 1
Note, that output file name has been changed, too.
The mesh produced by that command can be seen in this figure:
mesh = pv.read(f"{out_dir}/quads_graded_init_size.vtu")
show_mesh(mesh)
In many cases it may be useful to set a maximal cell size.
That can be achieved via the --d$direction-max $value
parameter.
The command from the previous step can be expanded by: --dx-max 2
! generateStructuredMesh -e quad -o {out_dir}/quads_graded_max_size.vtu --lx 7 --ly 4 --ny 5 \
(click to toggle)
--mx 1.2 --dx0 1 --dx-max 2
Note that the length of mesh and numbers of cells has been modified compared to the previous step in order to improve visibility of the effect of the maximum cell size parameter.
mesh = pv.read(f"{out_dir}/quads_graded_max_size.vtu")
show_mesh(mesh)
In previous examples only 2D meshes were created.
createStructuredMesh
is capable of creating 3D meshes, too.
In order to create one, the element type has to be changed to a 3D one and parameters --lz
and --nz
need to be passed additionally.
In 3D, the quadrilateral element type has to be replaced by hexahedral one.
! generateStructuredMesh -e hex -o {out_dir}/hexes.vtu --lx 7 --ly 4 --lz 3 --nx 10 --ny 5 --nz 3
[32minfo:[m Mesh created: 264 nodes, 150 elements.
The command above will create the following mesh:
mesh = pv.read(f"{out_dir}/hexes.vtu")
(click to toggle)
plotter.add_axes()
The following was mainly taken from https://www.opengeosys.org/docs/tools/meshing-submeshes/submeshes/
For Finite Element simulations, we need to specify subdomains e.g. for boundary conditions.
One possibility is to precompute the subdomains as meshes by extracting them from our domain.
This way the subdomains additionally contain information to identify the corresponding bulk mesh entities like nodes, elements, and faces of elements.
We can extract subdomains using the OGS tool ExtractBoundary
Type ! ExtractBoundary --help
for a basic documentation.
USAGE:
ExtractBoundary [-h] [--ascii-output] [--version] [-l <none|error|warn|
info|debug|all>] [-o <OUTPUT_FILE>] -i <INPUT_FILE>
-i <INPUT_FILE>, --mesh-input-file <INPUT_FILE>
(required) Input (.vtu). The name of the file containing the input
mesh
Output (.vtu). The name of the file the surface mesh should be written
to
--ascii-output
If the switch is set use ascii instead of binary format for data in
the vtu output.
debug|all>
--, --ignore_rest
--version
-h, --help
Tool extracts the boundary of the given mesh. The documentation is
available at
https://docs.opengeosys.org/docs/tools/meshing-submeshes/extract-boundar
y.
We start with extracting the boundary of a 2D mesh.
Let’s remind ourselves of the mesh by visualizing it once more.
show_mesh(mesh)
From above we can see the required arguments for using the ExtractBoundary
tool.
We pass in the mesh to extract the boundary from quads.vtu
and save the boundary to quads_boundary.vtu
! ExtractBoundary -i "{out_dir}/quads.vtu" -o "{out_dir}/quads_boundary.vtu"
[32minfo:[m Mesh read: 30 nodes, 20 elements.
[32minfo:[m 0 property vectors copied, 0 vectors skipped.
[32minfo:[m Created surface mesh: 18 nodes, 18 elements.
Visualize the output mesh:
boundary_mesh = pv.read(f"{out_dir}/quads_boundary.vtu")
show_mesh(boundary_mesh)
As shown above, the boundary of a 2D mesh is just a set of lines.
We can use the same command to extract the boundary of a 3D mesh.
# Using a previously generated mesh
(click to toggle)
! ExtractBoundary -i "{out_dir}/hexes.vtu" -o "{out_dir}/hexes_boundary.vtu"
[32minfo:[m Mesh read: 264 nodes, 150 elements.
[32minfo:[m Created surface mesh: 192 nodes, 190 elements.
And visualize it:
boundary_mesh = pv.read(f"{out_dir}/hexes_boundary.vtu")
show_mesh_3D(boundary_mesh.shrink(0.8))
The tool removeMeshElements
removes those elements from a given input mesh that fulfill a user specified criterion.
The resulting mesh will be written to the specified output file.
Type ! removeMeshElements --help
USAGE:
removeMeshElements [-hz] [--inside] [--invert] [--outside] [--version]
[-l <none|error|warn|info|debug|all>] [-n
<PROPERTY_NAME>] [-t <point|line|tri|quad|hex|prism|
tet|pyramid> ...] [--max-value <MAX_RANGE>]
[--min-value <MIN_RANGE>] [--property-value
<PROPERTY_VALUE> ...] [--x-max <MAX_EXTENT_X>]
[--x-min <MIN_EXTENT_X>] [--y-max <MAX_EXTENT_Y>]
[--y-min <MIN_EXTENT_Y>] [--z-max <MAX_EXTENT_Z>]
[--z-min <MIN_EXTENT_Z>] -i <INPUT_FILE> -o
<OUTPUT_FILE>
--invert
inverts the specified bounding box
largest allowed extent in z-dimension
smallest allowed extent in z-dimension
largest allowed extent in y-dimension
smallest allowed extent in y-dimension
largest allowed extent in x-dimension
smallest allowed extent in x-dimension
-z, --zero-volume
remove zero volume elements
-t <point|line|tri|quad|hex|prism|tet|pyramid>, --element-type <point|
line|tri|quad|hex|prism|tet|pyramid> (accepted multiple times)
element type to be removed
-n <PROPERTY_NAME>, --property-name <PROPERTY_NAME>
name of property in the mesh
--property-value <PROPERTY_VALUE> (accepted multiple times)
value of selected property to be removed
minimum value of range for selected property
maximum value of range for selected property
--outside
remove all elements outside the given property range
--inside
remove all elements inside the given property range
written to
mesh
debug|all>
--, --ignore_rest
--version
-h, --help
Removes mesh elements based on element type, element volume, scalar
arrays, or bounding box . The documentation is available at
https://docs.opengeosys.org/docs/tools/meshing/remove-mesh-elements.
The user can choose between 4 different removal criteria:
Let’s load the boundary mesh that we have extracted in the last step:
(click to toggle)
xmin, xmax, ymin, ymax, zmin, zmax = boundary_mesh.bounds
BoundsTuple(x_min=0.0, x_max=7.0, y_min=0.0, y_max=4.0, z_min=0.0, z_max=3.0)
We remove all mesh elements except for the ones at the minimum z-value i.e. the plane at the minimum z-value.
! removeMeshElements -i "{out_dir}/hexes_boundary.vtu" -o "{out_dir}/hexes_zmin.vtu" --z-min {zmin + 1e-8}
(click to toggle)
mesh = pv.read(f"{out_dir}/hexes_zmin.vtu")
show_mesh_3D(mesh.shrink(0.8))
[32minfo:[m Mesh read: 192 nodes, 190 elements.
[32minfo:[m Bounding box of "hexes_boundary" is
x = [0.000000,7.000000]
y = [0.000000,4.000000]
z = [0.000000,3.000000]
[32minfo:[m 140 elements found.
[32minfo:[m Removing total 140 elements...
[32minfo:[m 50 elements remain in mesh.
[32minfo:[m Removing total 126 nodes...
We can also remove all other bounding planes and plot them.
! removeMeshElements -i "{out_dir}/hexes_boundary.vtu" -o "{out_dir}/hexes_zmax.vtu" --z-max {zmax - 1e-8}
(click to toggle)
! removeMeshElements -i "{out_dir}/hexes_boundary.vtu" -o "{out_dir}/hexes_xmin.vtu" --x-min {xmin + 1e-8}
! removeMeshElements -i "{out_dir}/hexes_boundary.vtu" -o "{out_dir}/hexes_xmax.vtu" --x-max {xmax - 1e-8}
! removeMeshElements -i "{out_dir}/hexes_boundary.vtu" -o "{out_dir}/hexes_ymin.vtu" --y-min {ymin + 1e-8}
! removeMeshElements -i "{out_dir}/hexes_boundary.vtu" -o "{out_dir}/hexes_ymax.vtu" --y-max {ymax - 1e-8}
[32minfo:[m 175 elements found.
[32minfo:[m Removing total 175 elements...
[32minfo:[m 15 elements remain in mesh.
[32minfo:[m Removing total 168 nodes...
[32minfo:[m 160 elements found.
[32minfo:[m Removing total 160 elements...
[32minfo:[m 30 elements remain in mesh.
[32minfo:[m Removing total 148 nodes...
(click to toggle)
plotter.add_mesh(pv.read(f"{out_dir}/hexes_xmin.vtu").shrink(0.8), lighting=False, color="red")
plotter.add_mesh(pv.read(f"{out_dir}/hexes_xmax.vtu").shrink(0.8), lighting=False, color="orange")
plotter.add_mesh(pv.read(f"{out_dir}/hexes_ymin.vtu").shrink(0.8), lighting=False, color="green")
plotter.add_mesh(pv.read(f"{out_dir}/hexes_ymax.vtu").shrink(0.8), lighting=False, color="yellow")
plotter.add_mesh(pv.read(f"{out_dir}/hexes_zmin.vtu").shrink(0.8), lighting=False, color="blue")
plotter.add_mesh(pv.read(f"{out_dir}/hexes_zmax.vtu").shrink(0.8), lighting=False, color="cyan")
plotter.add_axes()
plotter.window_size = [800,400]
At the moment (Sep 2024) the ExtractBoundary
tool unfortunately does not support extracting the zero dimensional boundary of
a one dimensional mesh.
To create such zero dimensional meshes suitable for source terms and boundary
conditions in OGS the following can be done, among others.
First, create a gml
file with the following content. Change point coordinates
to your needs.
<?xml-stylesheet type="text/xsl" href="OpenGeoSysGLI.xsl"?>
<name>geometry</name>
<points>
<point id="0" x="0.0" y="0.0" z="0.0" name="source"/>
</points>
</OpenGeoSysGLI>
Then, run constructMeshesFromGeometry
which will produce a mesh consisting of the single point and set up for use with
OGS:
constructMeshesFromGeometry -m SIMULATION_DOMAIN.vtu -g THE_GML_FILE_YOU_JUST_CREATED.gml
show_mesh()
.# Put your solution here
# Visualize your result
mesh_name = "" # Put your mesh name inside the ""
mesh = pv.read(f"out/{mesh_name}")
show_mesh(mesh)
Consider the mesh from the beginning of the previous step:
Remove all elements from this mesh that are not at the mesh boundary.
mesh_name = "" # Put your mesh name inside the brackets
mesh = pv.read(f"{out_dir}/{mesh_name}")
show_mesh(mesh)
! generateStructuredMesh -e tri -o {out_dir}/ex1_triangle.vtu --lx 3 --ly 4 --nx 7 --ny 6 --ox 5 --oy 1
(click to toggle)
# Visualize the result
mesh_name = "ex1_triangle.vtu" # Put your mesh name inside the brackets
show_mesh(mesh)
[32minfo:[m Mesh created: 56 nodes, 84 elements.
# Extract boundary
(click to toggle)
# Extract boundary
! ExtractBoundary -i "{out_dir}/quads.vtu" -o "{out_dir}/ex2quads_boundary.vtu"
# Visualize result
mesh_name = "ex2quads_boundary.vtu" # Put your mesh name inside the brackets
show_mesh(mesh)
(click to toggle)
# Created with: ! generateStructuredMesh -e hex -o out/hexes.vtu --lx 7 --ly 4 --lz 3 --nx 10 --ny 5 --nz 3
mesh
UnstructuredGrid | Information |
N Cells | 150 |
N Points | 264 |
X Bounds | 0.000e+00, 7.000e+00 |
Y Bounds | 0.000e+00, 4.000e+00 |
Z Bounds | 0.000e+00, 3.000e+00 |
N Arrays | 0 |
From the above cell’s output we see that ‘N Arrays == 0’. This means there is no data contained.
mesh = pv.read(f"{out_dir}/hexes_boundary.vtu") # Created by ExtractBoundary tool
mesh
Header | Data Arrays | ||||||||||||||||||||||||||||||||||||||
mesh = pv.read(f"{out_dir}/hexes_xmax.vtu") # Created by ExtractBoundary tool and processed by removeMeshElements
mesh
What is this data used for?
bulk_node_ids
identify where the contributions of BCs and STs will go in the global equation systembulk_element_ids
, bulk_face_ids
used with some advanced features, e.g. special BCs and surface flux computationOGS will complain if the needed data is missing for BC or ST meshes.
bulk_mesh = pv.read(f"{out_dir}/hexes.vtu")
(click to toggle)
bulk_mesh.point_data["bulk_node_ids"] = np.arange(bulk_mesh.n_points)
boundary_mesh = pv.read(f"{out_dir}/hexes_xmax.vtu")
# move the mesh a bit for better visualization
boundary_mesh.points[:,0] += 1
plotter.add_mesh(bulk_mesh, scalars="bulk_node_ids", show_edges=True, lighting=False)
plotter.add_mesh(boundary_mesh, scalars="bulk_node_ids", show_edges=True, lighting=False)
plotter.add_axes()
(click to toggle)
bulk_mesh.cell_data["bulk_element_ids"] = np.arange(bulk_mesh.n_cells)
# Move the mesh a bit for better visualization
plotter.add_mesh(bulk_mesh, scalars="bulk_element_ids", show_edges=True, lighting=False)
plotter.add_mesh(boundary_mesh, scalars="bulk_element_ids", show_edges=True, lighting=False)
plotter.add_axes()
This article was written by Christoph Lehmann, Feliks Kiszkurno, Frieder Loer. If you are missing something or you find an error please let us know.
in CI job 635984
Last revision: October 13, 2023
